sts cam suggestions
Old Apr 28, 2009 | 02:55 PM
gmc6.0's Avatar
Default sts cam suggestions
hey im wondering what you guys would recommend for a good cam i use my truck highly as a dd and mildly on the strip...i dont really tow anything but i dont want the choppy sound....i have the sts setup on a cc sierra lifted. but i plan on geting the kbracing front mount or something like that later down the road so i dont wanna change the cams agian...any suggestion also what pushrods would be good...thaks
Old Apr 28, 2009 | 03:02 PM
454navyss's Avatar
how about an 02+ ls6 cam
Old Apr 28, 2009 | 03:07 PM
gmc6.0's Avatar
is that a good choice what would be good rods length wise..
Old Apr 28, 2009 | 03:27 PM
LMSeven's Avatar
Yes it is a good choice power wise and cost wise. I'm pretty sure the base circle is smaller, but standard 7.4" push rods will do. I'd get the valve springs too, their only $50. I've seen a Z06 cammed 5.3 truck w/ sts make 480rwhp/tq pump gas no meth on a safer tune.
Old Apr 28, 2009 | 03:42 PM
454navyss's Avatar
i have some yellow ls6 valve springs i'll sell you for $50 plus shipping. i just bought them but have decided to go with different springs with a tr224. pm me if you want them
Old Apr 28, 2009 | 04:31 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
what's the motor?
Old Apr 28, 2009 | 07:05 PM
gmc6.0's Avatar
the motor is an lq9. i plan to change my lifters reason being is im getting that ticking noise and from using the search button it sounds to me that the lifters are the most common problem so im thinking ls7 lifters ls6 cam with the standard rods, springs should i get the yellow ls6?? are the stock 317 heads rockers good if not what would be a good upgrade...i have the rear mounted sts trying to get 550-600 rwhp on a lifted cc sierra.
Old Apr 28, 2009 | 07:09 PM
GMCtrk's Avatar
Ideal pushrod length with the LS6 cam would probably be between 7.425 and 7.450"
nonnieselman's Avatar
shoot Stock48 a pm.. he is an isky dealer.
Ill be getting a 215/215 .567/.567 114lsa from him shortly
Old Apr 28, 2009 | 07:27 PM
Mangled03gmc's Avatar
Baltimore Whore
Why you going with a single pat cam Jon...??
The ls6 is a good cheap up grade, yes you will want rods longer then 7.4 due the smaller BC on the cam...
