strokers
Old Jun 4, 2007 | 06:24 AM
catman22's Avatar
Talking strokers
Does anybody have a spec sheet that shows how many cubes you can get out of all the engines 4.8,5.3,5.7,and 6.0 let me know something, later
Old Jun 5, 2007 | 01:07 PM
silent1's Avatar
With all keeping their stock bore?
4.8/5.3 w/ 4" crank - 360ci
w/4.125" crank - 370ci
w/4.2" crank - 377ci
5.7 w/ 4" crank - 382ci
w/ 4.125" crank - 394ci
w/ 4.2" crank - 401ci
6.0 w/ 4" crank - 402ci
w/ 4.125" crank - 414ci
w/ 4.2" crank - 422ci
Old Jun 6, 2007 | 04:26 PM
catman22's Avatar
thanks man this is what I wanted, now I guess all you have to do is figure the bore if it was to be bored and you are in business, later.
Old Jun 7, 2007 | 03:20 PM
moes04silverado's Avatar
what are the stock cranks in all these blocks? Im curious on how to build a 370 out of a 4.8 block
Old Jun 7, 2007 | 03:56 PM
silent1's Avatar
4.8 stroke-3.26
5.3, 5.7, and 6.0 use the same stroke-3.62
Old Jun 7, 2007 | 03:58 PM
silent1's Avatar
BTW, in NO way is a 4.125" crank recommended for a 4.8/5.3 block. I don't know how far you can bore a 4.8/5.3 block(stock bore is 3.78"), but a 3.85" bore and 4" crank would get you 372ci.
Old Jun 7, 2007 | 05:17 PM
quicksilverado's Avatar
Use a 6.0 blocked bored .030 over with stock crank and rods. If you are going F/I use forged rods and pistons with the stock crank. Much cheaper than the 4.8. You save on the crank and all the headaches of making a stroker that big work with the 4.8 block.
Old Jun 7, 2007 | 10:01 PM
i know but i thought it would be different
maybe ill just make a iron block ls1 from my 4.8
Old Jun 9, 2007 | 10:51 AM
corvette_uae1's Avatar
so guyz do u mean the 4.8 iron block ( stock ) its danger and unsafe to put a 383 stroker kit !!!???? i dont want to bore my block so much so thats if something happen i can bore it again not throw the block .
Old Jun 9, 2007 | 12:02 PM
silent1's Avatar
You need to get your block sonic tested to see if it has enough material to safely go to the necessary 3.9 bore.
