Stripped exhaust manifold bolt hole
Old Nov 25, 2015 | 02:52 PM
GRRR65GTO's Avatar
Default Stripped exhaust manifold bolt hole
My truck started ticking again due to the manifold warping away from the head and its because the hole is now stripped apparently from with a cross threaded it. I used a thread chaser to fix the threads but it wasnt strong enough i guess. I know helicoils are supposed to bet the strongest fix but in a standard kit the helicoil is only 12 mm long and the bolts are longer than that. Is that still the best fix? Or would I be better going up a size to a m10 I wonder. Any input is appreciated thanks
And I didnt know which section would best fit this so mods move if im wrong
Old Nov 25, 2015 | 03:14 PM
ezdaar's Avatar
The strength of threads only goes to the width of the bolt threading into it.
Any more os just extra that provides no more shear strength.
Use your 12mm helicoil with no worries.
Old Nov 25, 2015 | 04:17 PM
pewter6.0's Avatar
I've had issues with helicoils in the head that supports my log manifold. I run time serts and have had no issues since.
Old Nov 25, 2015 | 05:50 PM
kbracing96's Avatar
A helicoil is a ss wire inserted into an aluminum head. It is actually much stronger then the factory threaded hole. You will twist off a bolt before you pull out a properly installed helicoil in an aluminum head.
Old Nov 25, 2015 | 08:57 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You can buy longer lengths of helicoils you know...
The ones they sell in stores are usually most common for average repairs.
Old Nov 25, 2015 | 08:59 PM
brandon6.0's Avatar
Or re tap it and put a stud in it with quick steel. Works pretty good.
Old Nov 25, 2015 | 09:12 PM
ezdaar's Avatar
Why would self respecting motor head ever "quick steel" a stud into a engine anywhere!?
There is a term for that nonsense and its not compliant.
Old Nov 25, 2015 | 09:26 PM
FFDP's Avatar
Because racecar, duh.
Thinking outside the box has worked many times, doesnt matter if it's right or wrong.
Old Nov 25, 2015 | 11:21 PM
ezdaar's Avatar
Lulz! "Because racecar"
Old Nov 26, 2015 | 09:17 AM
GRRR65GTO's Avatar
Ok so helicoil it is it souunds like. Ill try to find a the longer version too just to make me feel better
