Stock to Edlebrock heads
Old Sep 20, 2009 | 01:35 PM
CurtD's Avatar
10 Second Truck Club
Default Stock to Edlebrock heads
For those of you that made the change did you have to change push rods?
Old Sep 20, 2009 | 03:38 PM
Fastcount03's Avatar
We need a lil more information on the swap so we can answer you correctly. What heads did you swap and mainly were they milled?
Old Sep 20, 2009 | 03:49 PM
broke1's Avatar
Banned
Sup Curt,long time no see,this is Bretts friend Drew.....
I will be going with the CNC'd l92 heads on my Escalade.Ive got a hookup on complete truck intakes(injectors,90mm tb,sensors,gaskets,COMPLETE) and complete l92 heads,everything brand new for around $850 shipped.
I sent my l92's to TEA for there Stg1 porting.They outflow any other manufactures l92's and they are CHEAP at $1100.Not to mention several guys are making over 500rwhp in mild NA setups.Id imagine that with your setup on kill,youd be over 1200rwhp if you have a turbo/IC that can flow the air...
If you saw these l92's in person,youd be shocked they were stock small block heads!!f u wanna have a look at a set before they go on an engine,gimme a shout and well meet up.
Old Sep 20, 2009 | 04:37 PM
CurtD's Avatar
The heads I took off were stock, not milled. The heads I'm putting on are Edlebrocks not milled.
Hey Drew, those sound like some nice heads.
Old Sep 20, 2009 | 06:06 PM
quicksilverado's Avatar
Are the decks thicker on the aftermarket heads Curt? I had to get new (longer push rods) when I switched to All Pro heads.
Old Sep 20, 2009 | 10:03 PM
terravast4's Avatar
The edelbrock are direct replacements.
Old Sep 21, 2009 | 05:55 AM
CurtD's Avatar
Yep, they are thicker...I'll have to get a push rod length checker.
Old Oct 9, 2009 | 08:32 PM
Casey2323's Avatar
Default hey man
LONG TIME NO SEE !!!!!!!!!!..... Nice to see you posting again ..... Call me sometimes ... I have lots of info to share...
Old Oct 9, 2009 | 08:42 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I hope you went with some p&p'd 245s :thumbs: (And yes, substantially thicker deck on those, so you'll likely end up with new push rods).
Old Oct 9, 2009 | 11:14 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
On my 420 the normal 7.4 PRs worked fine with my 245 edelbrocks from WCCH. I believe the thicker deck is internal, otherwise if it actually pushed the total height of the head higher off the deck of the block you would have intake alignment problems.
thunder550
Oct 8, 2015 04:53 PM
lxcoupe
Jul 30, 2015 02:42 PM
sauldgold
Jul 23, 2015 02:15 PM
06 4.8
Jul 15, 2015 07:17 PM
4B11T
Jul 13, 2015 03:48 PM
