Spinning up a LQ9
Old Oct 21, 2005 | 10:42 PM
Default Spinning up a LQ9
How high have you guys spun a stock bottom -ended LQ4 or LQ9? I will have a strong enough valve train to handle high rpm, but I don't know what the bottom end can take. I plan on using Katech rod bolts, and hopefully I can spin it to 7000 rpms more than once. Anyone spin this high or go higher?
Old Oct 21, 2005 | 11:28 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Wouldnt go over 7000 with it thats about the limit of the stock crank from what I have rread and seen on a few threads on tech. The rod bolts helps alot. Im going to spin my 408 up to bout 6800 and thats it. I want it to last unlike the the 5.3
Old Oct 22, 2005 | 07:47 AM
Fogle07's Avatar
turn it till it stops pullin haha. i turn my stock bottom 5.3 to 6800 ok im just kidding i turn it 6400. id turn it prob. like 6700-6900 and thats it. its all according to what cam you have i think
Old Oct 23, 2005 | 12:54 PM
SPRAYEDSIERRA's Avatar
11 Second Club
Stock bottom end LQ9 shifted at 6800, 10 passes with 175 shot, 4 passes with 250 shot, still going strong
Old Oct 23, 2005 | 01:59 PM
1slow01Z71's Avatar
Your **** is living on borrowed time by far. I bet when you pull the motor when it blows and look at the pistons they are all melted on top. I have seen what a 150 shot can do to a stock piston I can imagine what a 250 does to it. Alot of keeping a motor together has to do with tuning and obviously yours is perfect.
Btw i spun my 168,000 mile 5.3 up to 6700 with now problem. Fried the rings with the nitrous though I believe but still havent pulled the lotor to know for sure yet.
Old Oct 23, 2005 | 04:33 PM
Sounds like fun! I giess turning o the shift light at 6600 and shifting at 6800 will work fine.
Old Oct 23, 2005 | 07:03 PM
litreddevil's Avatar
Banned
i have turnned my 7280 i made a pass and took a snap shot with the tech 2 i shifted my 1 2 shift @ 7280
00loudchevy
Dec 3, 2015 05:54 PM
gmcyukon
Oct 5, 2015 06:20 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
The_W
Oct 1, 2015 02:35 PM
