Spark plugs? which ones for the cam?
Originally Posted by bluecajun5.3
yep. is allen doing your tune? if so, he suggested that the stock plugs were fine for my application.
. After I get it running I'll take it over to him and let him do a live tune to get everything dialed in.I'm also going to have my current tune(w4me) updated for a comparison
Originally Posted by closet red neck
I run two different temps....a summer and a winter plug. The tr55's in the summer and #6's in the winter. If you care to know.?.?.
James
James
Here in Houston, we just have 2 seasons.....hot and DAMN HOT
what is the plug you refer to as "#6"?
James
The temp. Like a number 7,8,9,......is hotter. Allen tuned my truck with 35 degrees of timing and in the winter it would detonate, so I put a colder plug in it and cured this. Then in the summer if I kept the #6 in, it would run fat so in goes the hotter plug(tr55's) to accomodate the temp change. Does this make any sense??? Not being an *** or anything......LOL!
James
James
damn, that's a whole lot of advance. i'm running 28*. when i get back to the states i'll have to bump it up to see if there is more power to be found.
!!! It run like a bat out of hell!! Cody said that my truck is faster than his old 5.3 with a cam and it being and xcab also. I haven't installed anything yet in the engine. I just ordered my flex plate, 3800 verter, DS, locker and diff cover on thursday. All will be here mid next week!!!!!!
James
The theory makes sense...I'm just not familiar enough with the gen III plugs to know the lingo.
Colby, NGK's are stock in some of these motors. When I replaced mine (which I didn't need to do) NGK on one side and Delco on the other. I would think depending on your tune the TR55 would be fine, pick em up at Oreilly. You can look up the part number on their web site.
I think I was running around 30* timing until recently when it started to get hot, and had to have my tuner back it down to stop the pinging until it gets cool again.
