Some pics of my strokin' short block
Old Oct 19, 2007 | 08:40 AM
Savage Sierra's Avatar
Default Some pics of my strokin' short block
Here are some pictures of my 383 stroker small block-short block. Finished it a few days ago, will get some assembled pics up over the weekend.
4.020 bore (380 cid)
Eagle: cast steel stroker crankshaft [3.75]
Eagle: SIR-I Beam 5.7 Rods
Keith Black: Hyperutectic, coated, 10:1 pistons with 65.3 cc iron heads
ARP: all fastners are ARP. Studed main caps, rod bolts, etc.
Old Oct 19, 2007 | 08:48 AM
TurboGibbs's Avatar
Nice, what heads cam and intake you going with and is it going to be fuel injected?
Old Oct 19, 2007 | 09:07 AM
Heads are iron 193's re-worked, cam is a Crane H-266-2: 210/216, .440/.454, 114 LSA
Intake: Edelbrock 3704 Performer TBI, Holley 670 cfm 104 mm (52x2mm) TBI, Walbro 255 in tank fuel pump, 85 lb/hr injectors, 21 psi @ 80% Duty Cycle. Sinister Performance custom off road tune.
RPM range 2000-5000, built for monster low end power, stop light to stop light. Should run around 1.8 sixty foot times, low 9's in the eighth and mid to high 14's in the quarter. Which is repectable for an OBS, extended cab.
May run a NOS TBI plate system (125 shot) for chits and giggles. 13.90's maybe, with nitrous.
Old Oct 19, 2007 | 05:55 PM
dirt track racer 81's Avatar
i got the same crank and rods you got in my race..must be ok cause mine aint blown yet
Old Oct 19, 2007 | 09:32 PM
TurboGibbs's Avatar
ought to be a torque monster for sure.
Three6GMC
Oct 27, 2015 08:04 PM
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Gadgetized
Jul 22, 2015 11:55 AM
