So no BS what is the biggest cam lq9/4
Old Apr 6, 2013 | 05:47 PM
diRty?biRd's Avatar
Originally Posted by 1-87 chevy
I run a g5x4 in an lq4 with 243s.
Ahhh, the cam with the mythical specs!!!! Hava any vids of it?
Old Apr 6, 2013 | 07:00 PM
MPFD's Avatar
11 Second Truck Club
I ran a 236/244 .620 .617 on a 110 in my LQ4 with .243's milled .020" and .040" gaskets. I popped it, but it cleared fine. Never had the driveability I was after. But the setup was a little miss matched...
Old Apr 6, 2013 | 07:38 PM
Team Paulie's Avatar
Registered User
baby 228R.....in mine.
Old Apr 6, 2013 | 11:17 PM
diRty?biRd's Avatar
What drivability issues did it have? What stall were you running? That thing must have sounded like a beast on a 110.
Old Apr 6, 2013 | 11:29 PM
LS1TRUCKGUY's Avatar
curious as to why you are looking at huge lift numbers? what will this be going in and what are you going to be doing with it? the"biggest" isnt always best. not trying to start a pissing mach here, but a little more info on your setup would help
Old Apr 7, 2013 | 10:42 AM
1-87 chevy's Avatar
new cam idle g5x4 - YouTube heres an idle clip of the g5x4
Old Apr 7, 2013 | 11:20 AM
zero2sixT's Avatar
After some experience, I'd start with a nice set of heads and then run a cam grind to complement them. Only if I was going to go n/a, of course. And looking back, I wouldn't go n/a.
Old Apr 7, 2013 | 07:53 PM
MPFD's Avatar
It was on a Maf tune, and I never did get the surging to completely go away. I used to have an idle clip in my sig. It was pretty good till ambient air temps got over 90 degrees. That when it was the worst. I was running a stock truck intake, TB, induction, and air box. I think it could have been better if I had upgraded the intake before I broke it. 3600 Yank,
DUSTIN 2.MP4 - YouTube
http://www.youtube.com/watch?v=QyIRIIUTIIc
DUSTIN 4.MP4 - YouTube
Old Apr 8, 2013 | 09:22 AM
TXsilverado's Avatar
that was probably cutting it pretty close. i have a LS2 with TFS 225 heads and had to cut .090 off of the intake side to clear a 236/242 110+4. .090 got me bare minimum clearance.
Old Apr 8, 2013 | 10:17 AM
MPFD's Avatar
Yeah but an LS2 would have flat tops right? Mine where the dished. Plus lift has nothing to do really with clearing, it's all in the valve timing event's. I would imagine the +4 had some to do with your clearance problem. Mine had no advance ground in.
