Sludge
Old Apr 16, 2008 | 11:01 PM
  #41
hirdlej's Avatar
August 18th 2006 and September 13th 2006. Looks to be your engine was made in late september then sometime and then installed in an '07 model year truck. You got what you paid for so don't worry there. I would tip the engine upsidedown on the engine stand and fill the crankcase with kerosene. Let it loosen the sludge up for a few days then start wiping it down and vacuuming it out. I don't see this being unreasonable. I wouldn't loosen up anything on the bottom end or undo any bolts that hold the rotating assembly. The bearings are more than likely fine. If you also use a high detergent oil for the first few oil changes it should help clean it as well.
Old Apr 16, 2008 | 11:11 PM
  #42
SpoolinChevy's Avatar
I didn't think about that. I might try it. I am going to take the intake off and look at the galley tomorrow to see if i can get any more out. I'll post up then.
Old Apr 17, 2008 | 04:56 PM
  #43
Well, i was pretty surprised. It doesn't look bad internally. Crosshatch looks good too.
Old Apr 17, 2008 | 07:01 PM
  #44
chevyguy7802's Avatar
Looks good in those pics!
Old Apr 17, 2008 | 08:31 PM
  #45
budhayes3's Avatar
PT's Slowest Truck
Looks good
Old Apr 18, 2008 | 12:46 AM
  #46
joeyc125's Avatar
11 Second Truck Club
i usually run a quart of trans fluid in with the oil for 20 miles before i change it every once in a while, it is a great cleaner, when i put my cam and springs in my motor looked absolutely new, heads werent stained or sludged up, valve covers had nothing on them, my work truck has almost 300k on its 6.0 motor and i pulled a valve cover a while back out of curiousity and it looked pretty good as well, never used sea foam in the oil, but im sure it works as well. good luck
Old Apr 18, 2008 | 09:17 PM
  #47
Pulled the cam tonight, to find this.
Old Apr 19, 2008 | 04:38 AM
  #48
ZZebes's Avatar
Well lookey there, someone just slammed shut that light at the end of the tunnel. sorry man
Old Apr 19, 2008 | 07:48 AM
  #49
dewmanshu's Avatar
Moderately Differentiated
Well...that sucks. Now you know what gotta do. Whack whoever sold you that motor over the head with the cam. Or mail them that bearing if they live far away. Hope you aren't into it very much as far as $ goes. Got her apart, build it with solid parts now.
Old Apr 19, 2008 | 10:14 AM
  #50
hirdlej's Avatar
I can't tell by the pics..... Is that rust or copper exposed on the bearing?
