Run of bad luck but good out come
Well to start had heads built and turned out well by flowing 316cfm @ 600.
Bought 40# injectors and harland sharp roller rockers. So then only to find out that my block was cracked. So I recently purchased the 408 from TSP, how do you think these items will work on the 408. I have a ported throttle body with a ls6 intake and bought a new ported oil pump and double timing chain. Well I have some recovering to do before I build another set of heads but should be a good foundation to work with.
241 castings mowed down .020. That is what was on the other set up. Will be upgrading soon just have to recover from the recent events. It is a custom ground cam from Erson 286/294 @ .578 112+2 and @ .050 it is 220/231.
GMCtrk
Jul 17, 2015 06:39 PM
