Which rotating assembly is best??
From what I've read and done searches on I cannot find a definitive answer to the question. Scat, Eagle, Callies, Lunati, Wiesco, etc... Now I know this is an extremely complicated question since a lot of guys mix and match different cranks, rods, and pistons from different makers, but what is the best quality of all of those parts all around? I am wondering what is the best rotating assembly in terms of reliability, quality, strength, and ability to withstand high horsepower applications for LSX engines?
depends on how much power, after about 1300-1500 hp you should go to a an aluminum billet rod which are huge bucks and need to be replaced every so often.
crank , there are a few places that make custom billet cranks and they are stronger than an off the shelf crank but cost huge bucks as well as take forever to be made. however with the lower priced forged cranks dont usually have problems when pushed.
pistons is alot of preference.
on a side note , i wanted strong stuff for my build 1200 hp area.
i went with a callies dragonslayer crank , lunati pro billet connecting rods and some custom coated diamond pistons.
blown02408
Oct 1, 2015 01:06 AM
1998, assembly, assy, callies, compstar, crankshaft, dragonslayer, f150, highest, horsepower, hp, lq4, makes, performance, power, rating, rotating
