Roller rockers
Old Dec 20, 2017 | 12:52 PM
turboal1's Avatar
Default Roller rockers
Has anyone used 1:8 RR on square port heads ?
what brand ?
Old Dec 22, 2017 | 11:41 AM
RPMSpeed Tech's Avatar
Truck Sponsor
what brand ?
The valves are heavy enough without adding more to them really. 1.8 on a stock cam or anything peaking at less than 6200ish would be ok, but why not just get a higher lift cam?
Old Dec 22, 2017 | 12:31 PM
turboal1's Avatar
Default Rollers
I was just looking to make my life
easier by just throwing on a set of rocker arms
instead of swapping a cam again. it's a PIA in my
truck, not a lot of room to work in the eng bay.
Old Dec 22, 2017 | 12:42 PM
Truck Sponsor
What cam? The lobes will matter and springs as well.
Ive used scorpion alot. I like em. Not too heavy over the valve.
Old Dec 23, 2017 | 11:42 AM
turboal1's Avatar
Default parts
Have Comp VVT cam, Pack 1219 springs.
was looking at Comp Ultra Pro Magnum 1.8 rockers
Old Dec 23, 2017 | 12:00 PM
Truck Sponsor
Id say no on vvt cams.
Old Dec 23, 2017 | 11:23 PM
Duntov1967's Avatar
I don't know much about VTT but 1:8 rockers will benefit you in the torque department as they increase the velocity by lifting the valve quicker. Of course there is the benefit of more lift as-well. This is a method used by Roger Vinci who knows much about cams for our heavy trucks. My cam is fairly small: DUR @ .050" 210* / 222*, LIFT .551 /.551, LSA 116* (.585 lift with 1.8 ratio rockers). I use Yella Terra rockers. The heads are L92's with very good double springs and a 2.9L Whipple on top.
Old Dec 23, 2017 | 11:46 PM
Truck Sponsor
Imo the vvt runs into a more unpredictable territory where, even though the phaser is limited, youre effectively adding more lift/duration and may run into issues depending on how aggressove the cam is or the lsa and icl and of course overall duration at all points.
Old Dec 23, 2017 | 11:54 PM
Duntov1967's Avatar
Sounds like good arguments to dump the vvt.
Old Dec 23, 2017 | 11:56 PM
Truck Sponsor
On the dodge vvt, if you use too much spring pressure youll throw a vvt code. not sure on the gms.
.but you are putting quite a bit more strain on the cam doing so then add more spring pressure on top.
Besides i dont like vvt anyway. Ive never seen it gain vs a std design cam.
