Roller rocker ratio?
Old Dec 15, 2009 | 04:40 PM
joeoby78's Avatar
Default Roller rocker ratio?
Will stock clearance heads, valves, etc. on an '05 5.3L take 1.8+ ratio roller rockers?
Old Dec 15, 2009 | 04:50 PM
Mangled03gmc's Avatar
Baltimore Whore
Use a stock ratio rocker.. No really
Old Dec 15, 2009 | 05:05 PM
thunder550's Avatar
High on diesel fumes
1.8's will work....but...
this is the way to go. Not much to be gained by going to a roller rocker or a higher ratio rocker. If you want the extra lift, get it ground into the cam. Much cheaper that way.
Gadgetized
Oct 22, 2015 09:06 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
old motorhead
Sep 29, 2015 08:22 PM
