rocker arm issue?
Old Jan 12, 2011 | 12:33 AM
prochargedtahoe's Avatar
Registered User
Default rocker arm issue?
I've got an 03 tahoe that I just put a set of yella terra 1.8 rocker arms on. The truck ran great before I installed them. put them on and now will not idle for crap. Any ideas guys??
Old Jan 12, 2011 | 01:50 AM
mhotrodscooter's Avatar
Welcome to pt.net. Have you had it retuned?
Old Jan 12, 2011 | 02:12 AM
Gadgetized's Avatar
Did you count how many turns it took to go from zero lash to being fully torqued down? Was that the only thing that you changed?
Old Jan 12, 2011 | 02:19 AM
Registered User
Not retuned yet, but shouldn't change THAT much.
All I did was torque them down in correct sequence to 22ft lbs.
Yes, this is all I changed.
Old Jan 12, 2011 | 05:47 AM
Gadgetized's Avatar
I think you should check how many turns it takes to reach the desired torque specs. Shoot for 1 1/2 turns. The turns before achieving the desired torque amounts tells you what the preload is. You might have to get different pushrods to be in the right area.
Old Jan 12, 2011 | 08:19 AM
Registered User
Ok. I will try that again. The only reason i even went with these, is because i got a killer deal on them and the stocks were rattling and coming apart. It's been a big pain in the *** though.
btw it doesn't just idle bad, it runs shitty too.
Old Jan 12, 2011 | 08:37 AM
budhayes3's Avatar
PT's Slowest Truck
Pull the valve covers and make sure that rockers aren't contacting the head back on the pushrod side, as well as the valve cover. I've seen pics of guys with the pushrod cup snapped right off from not having enough clearance between the rocker and the head, and the rocker binding on the head. If all is well, make sure that they're all tight, and that all of the valves are closing all of the way.
Old Jan 13, 2011 | 06:05 PM
Registered User
Well, I'm just going to put a set of stockers back on. Will be selling these if anyone is interested.
Thanks for the input
Old Jan 13, 2011 | 07:22 PM
00buckshot's Avatar
I would like to know what the problem you are having is caused by..........................
Old Jan 13, 2011 | 08:04 PM
Country Boy's Avatar
Senior Member
Only if its a "killer deal".
