Recommend some bearings for me
Old Nov 16, 2010 | 06:26 PM
swift700's Avatar
Default Recommend some bearings for me
Which bearings would you recommend for my 383 blown stroker build? I'll need crank and connecting rod bearings. What have you guys used and are you happy with them? I'm leaning towards Clevites. I know they make two different kinds, H and P. Which is better?
Old Nov 16, 2010 | 06:44 PM
Mangled03gmc's Avatar
Baltimore Whore
Clevite is all I have ever used.. H has a wide chamfer on the edge to fit the radius on the filets of performance cranks where P series are pretty much squared off at the edges and fit factory cranks better. If your going to use a aftermarket crank H might be what you want, a from my reading it is a more performance oriented bearing.... Also I believe the H's are a harder material then the P's.. Call and talk direct to them, to be sure, as I am not positive...
http://www.440source.com/bearings.htm
Old Nov 16, 2010 | 06:51 PM
silver-mod-o's Avatar
Hunt&Fisherator
Clevite H for you since this will definitey be using a longer than stock stroke.
Old Nov 17, 2010 | 09:36 AM
Sales2@Texas-speed's Avatar
Former Vendor
You need the H's for the aftermarket crank, P's will not fit correctly and will basically cause the oil to hemorrhage and cause terrible oil pressure.
lukn4trbl355
Oct 21, 2015 11:19 PM
Alco
Oct 4, 2015 06:58 AM
Wolftrk99
Oct 2, 2015 08:17 AM
sTNT971
Sep 26, 2015 04:22 PM
