Rebuilding my 05 SS need some help/advice
Old Jun 4, 2012 | 11:30 PM
jroctpb's Avatar
Default Rebuilding my 05 SS need some help/advice
I am looking for some help with an up coming head swap and have a few questions. My AWD 2005 Silverado SS just turned 170000 miles (all original drivetrain) the truck still runs like the day it was new, but I am thinking its time for a partial rebuild because I am planing a trick turbo kit soon, my plan is as follows.
Drivetrain
-New built trans
-rebuilt/beefed up rear end
-Probably leave the transfer case and front diff alone, thoughts?
Engine
-Replace cylinder heads with ported ones
-New lifters
-New pushrods
-New timing set
-New oil pump
-replace all gaskets
First thing I am going to do is heads, I am very inexpirenced actually working on engines so pulling the engine for a full rebuild is out of the question. I have done a ton of reading on here and feel comfortable enough to atempt a head swap here is my idea tell me what you think.
I am going to grab some 317 heads from the junkyard clean them up then port and polish them myself then instal new valve seats, seals COMP 918 springs (good for boost?) new retainers and keepers as well as new pushrods ,lifters, and rockers. I am going to do some ARP headstuds well they are off and new head gaskets (what head gaskets are best for boost?) thats all I can think of involving the headswap am i missing anything? Are there any tricks or tips before I attemp this? Thanks.
Old Jun 5, 2012 | 12:02 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Have you p&p'd before? If not, IMHO you're going to come out ahead by just buying a set of ported 317s. It's not easy, and getting it wrong will either ruin the head, or lead to poorly performing head.
Not for nuthin' but your truck has 317s already. I assume you are keeping the stockers?
For boost, you will need to go through the bottom end also.
Old Jun 5, 2012 | 12:23 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Welcome to the forum!!! You have alot of reading to do. There are plenty of threads around about home porting heads, Gaskets, and how to swap the parts you mentioned.
I would recommend starting with the turbo kit first. You may also want to considering building another engine while your enjoying the new turbo. You're most likely going to max out what the stock engine is capable of handling before you will see any benefits from a ported head with forced induction. You will probably also fry the trans and the transfer case in the meantime as well.
Old Jun 5, 2012 | 11:49 AM
Silverad0 SS's Avatar
Im doing a rear mount on my SS pm me if you got any questions and also join silveradoSS.com great info there for the SS's and great people
Old Jun 5, 2012 | 05:58 PM
jroctpb's Avatar
Thanks for the input, I will be sure to pm you if I need some help. I am also on silveradoSS.com (jroc)
Old Jun 5, 2012 | 06:14 PM
rcsb jon's Avatar
170,000 miles... you need all new bearings in that motor
Old Jun 9, 2012 | 11:45 PM
Atomic's Avatar
I have a gauge for that
I say go ahead and do the trans, but leave everything else and slap the turbo on. There are plenty of guys running turbos on high mileage engines making a ton of power.
03sierraslt
14
Oct 9, 2015 05:53 AM
gmcyukon
Oct 5, 2015 06:20 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 06:27 AM
97aztecgt
Sep 10, 2015 05:07 PM
