Rebuild 6.0L help
#111
#112
I was about to order those pistons from Rockauto, but my machinist got them for a few bucks cheaper. PM me if you want his info. LS2 rods are stronger than LQ4s. Make sure you have your crank balanced for the additional weight.
You mean the lifter retainer cap things? I re-used the stockers. lol, wouldn't that be ironic if that was what I thought the original piston slap was???
#114
#115
If I use a heavier spring, wouldn't the problem would be worse? The spring is opening by itself now.
#116
#118
#120
when you say the spring is opening you mean it gets bigger because the liffter is bleeding down taking the load off of it. that would in affect be the valve closeing up as a result...
Sorry dave, I don't want to sound rude I just want to make sure I am on the same page with you....
Well I dont want to poop
on your peraide but I hope your issue does not stem from those stupid things...
