Rebuild 6.0L help
Old Feb 12, 2009 | 09:03 PM
  #111
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by nickpc82
I found the pistons, are the ls2 rods a pretty good upgrade?
You have to use the LS2 rods with the LQ9/LS2 Pistons because they use a floating pin unlike the LS1/LQ4 Rods that had a pressed pin. Yes a floating pin set up is better
Old Feb 12, 2009 | 09:16 PM
  #112
clemsondave's Avatar
I was about to order those pistons from Rockauto, but my machinist got them for a few bucks cheaper. PM me if you want his info. LS2 rods are stronger than LQ4s. Make sure you have your crank balanced for the additional weight.
You mean the lifter retainer cap things? I re-used the stockers. lol, wouldn't that be ironic if that was what I thought the original piston slap was???
Old Feb 12, 2009 | 09:19 PM
  #113
http://cgi.ebay.com/ebaymotors/GM-LS...#ht_500wt_1085
Would these work?
Old Feb 12, 2009 | 09:20 PM
  #114
1FastBrick's Avatar
I mean the plastic trays that hold the lifters from turning side ways when installed in the block... No piston slap is pretty distinct sound... almost like bad bearings...
Old Feb 12, 2009 | 09:22 PM
  #115
I did not replace those.
If I use a heavier spring, wouldn't the problem would be worse? The spring is opening by itself now.
Old Feb 12, 2009 | 09:26 PM
  #116
that is the exact bid that I won
Old Feb 12, 2009 | 09:27 PM
  #117
1FastBrick's Avatar
Well I dont want to poop on your peraide but I hope your issue does not stem from those stupid things...
Old Feb 12, 2009 | 09:29 PM
  #118
1FastBrick's Avatar
Spring is opening by it self??? are you refering to the lifters and not the Valve springs...
Old Feb 12, 2009 | 09:33 PM
  #119
The lifter is falling and the spring is opening.
Old Feb 12, 2009 | 09:37 PM
  #120
1FastBrick's Avatar
when you say the spring is opening you mean it gets bigger because the liffter is bleeding down taking the load off of it. that would in affect be the valve closeing up as a result...
Sorry dave, I don't want to sound rude I just want to make sure I am on the same page with you....
