Rear engine cover question. Please help
Old Mar 19, 2007 | 10:30 PM
tarinitup's Avatar
9 Second Truck Club
Default Rear engine cover question. Please help
Had an oil leak on the new 402 motor and traced the problem to the rear cover. The cover that is on it right now has recessed bolt holes unlike the 5.3 cover and another 6.0 cover that we compared it to. Because the holes are recessed it doesn't tighten enough to seat the gasket properly. Can we use washers to make up the recessed difference or is it possible that it is the wrong cover? Block is an 2005 6.0.
Old Mar 19, 2007 | 10:38 PM
Quik's Avatar
5 year bitches!
thats new to me, so yoru saying the bolts bottom out before they clamp tight enough? why not try and put the 5.3 cover on it
Old Mar 19, 2007 | 10:42 PM
tarinitup's Avatar
9 Second Truck Club
trying not to disassemble the 5.3 so I can sell it with no problems. Have you ever seen a recessed rear cover?
Old Mar 19, 2007 | 10:51 PM
jetmann's Avatar
Default Been there
The most common problem is that the bolts are to long and the cover is not seated against the block. You could use washers if you are in A bind but the correct way is the shorter bolt. That happened to me once,but I caught the problem before it went to the customer. Rex
Old Mar 19, 2007 | 10:55 PM
tarinitup's Avatar
9 Second Truck Club
where did you get the bolts from? We tried some bolts from the 5.3 and they were the same length.
Old Mar 19, 2007 | 11:02 PM
Quik's Avatar
5 year bitches!
PM mater he has rear covers if you want to go that route
Old Mar 20, 2007 | 05:31 PM
RERICK's Avatar
Can't you just grind the bolts down ? Save some time and money . But your fingers could get burned.
Ron
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
Ketis
Jul 23, 2015 12:37 PM
jmarkway
Jul 18, 2015 09:23 PM
Furflyinjim
Jul 12, 2015 11:12 AM
