Raising compression, Changing Lifters & Cam
Old Nov 5, 2010 | 04:18 PM
  #31
Tootall's Avatar
Originally Posted by ByuTrukFreak
yeah trying to get 11:1 compression. I got a photobucket account. Will it automatically adjust the bytes and pixels so I can upload 'em?
it won't matter then on the file size . . . but try to upload them at 1024x768
Old Nov 22, 2010 | 08:13 PM
  #32
ByuTrukr's Avatar
formerly ByuTrukFreak
Here's what's happening, I got the heads done and the manifold won't fit, my heads have a lip where the intake goes (right under where the valve cover sits) and I had to have .050 shaved off that lip too. The intake has to have certain purge evaporator canister, I also needed another IAC motor since the one that came with the truck doesn't fit on the 102mm tb. You will need to drill certain blocked passages to make it work for PVC and MAP sensor. There are different bolts to put in the valley cover. You will need a different water vent line that connects to the front of the heads and block off the back ones. I still haven't tried to modify the fuel rails to fit either. My cam is still being ground so I'm waiting on that. Then it's anybodies guess what will happen from there.
Old Nov 23, 2010 | 02:54 PM
  #33
ForcedTQ's Avatar
Originally Posted by BlackGMC
honestly i don't think you can get to 11.0 CR... I think the most you could get is 10.5 milling them to 56cc and .04 head gasket...
You CAN get there, it's just going to require more work. Yes, mill the heads a bit, yes use a .040 head gasket, the one thing everyone missed here is the pistons he's using. Use a set of 4.8/5.3 OE flat-tops or Wiseco K474XS flat-tops if you wanted to go forged.
Old Nov 25, 2010 | 05:19 PM
  #34
ByuTrukr's Avatar
I'm gonna use the OE pistons it's the PTV clearance that I will be concerned about. Any bump in compression that I can get will be better than 9.5:1.
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
Suburban2500
Jul 19, 2015 04:50 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
