quick timing ?
Old 06-18-2009, 11:38 AM
NVS05GMC's Avatar
Default quick timing ?
Would being a tooth off on a 214/220 559/564 111.5 camshaft in a 05 gmc z71 with a L33 5.3, pac 1218, comp 7.4, tt3000, long tubes ory single 3" exhaust have the same performance as the stock camshaft?
Old 06-18-2009, 11:47 AM
NVS05GMC's Avatar
Forgot to mention tuned by nelson already got a retune he said that is as much timing he can give it without having the truck there. i live in chicago so thats not happening. Took the truck to the track and ran 15.2 with the stock cam and a 15.1 with the new cam im lost any ideas?
Old 06-19-2009, 09:36 AM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
a tooth is about 4*. Did you advance or retard? Who timed the cam?
How much spark does it have?
Old 06-19-2009, 10:46 AM
KySilverado's Avatar
Wouldn't shifting the camshaft timing just move the powerband of the cam? Advancing it putting the powerband lower in the rpm range, opposite for retarding it.
I would expect to still see a greater performance gain, unless it was retarded 4 degrees and on a stock stall killing its power gain.
Old 06-19-2009, 11:22 AM
I AM A MOTHERF*CKER
That's what I'm thinking.
Advanced cams offer more low end torque as well, so maybe he's blowing the tires off the line.
Old 06-19-2009, 01:40 PM
NVS05GMC's Avatar
Exact opposite its a dog till 4k i have a 3000 stall and it wont even spin the tires a lil when i floor it. stock cam it used to go up in smoke.
Old 06-19-2009, 03:09 PM
I AM A MOTHERF*CKER
So after 4k it feels strong?
Are you sure it's only one tooth off? Sounds like the cam is retarded a lot.
Old 06-19-2009, 03:23 PM
NVS05GMC's Avatar
Its dot to dot i already double checked last night im thinking i should advance it one tooth and see what happens the cam has no advance ground in to it see if that will bring my power range down.
Old 06-19-2009, 03:50 PM
I AM A MOTHERF*CKER
AhhH! I thought it was a tooth off. I think something else is up. Did you make sure you were at zero lash and proper preload?
Do a quick compression test -- low compression can mean your valve train components are mistuned.
I also assumed the 111.5 is lsa? Do you know the ICL?
Old 06-19-2009, 04:33 PM
NVS05GMC's Avatar
ICL is 110.5 and lobe seperation is 111.5 does that mean 1 degree of timing ground in? Im new at this im still learning. This cam was designed for a trailblazer ss from speed inc they ground it for a ls1 so the cam sensor would work. Could that be my prob they said it should work great in my truck.
Quick Reply: quick timing ?
