quick stupid question
Old 02-26-2009, 12:32 PM
lpguy's Avatar
Default quick stupid question
A pressure leak in the gas tank wouldnt cause a lean condition would it?
Old 02-26-2009, 01:33 PM
TX Tahoe Z71's Avatar
I wouldn't imagine so, I'm pretty sure that's not how they work. A leak in the fuel line, maybe, but that would probably be a bigger concern than running lean if you have gas spraying out under your truck.
Old 02-26-2009, 01:35 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
It will cause a code to be thrown...and in the Envoy the other day caused the engine to stall.....weird
Old 02-26-2009, 01:48 PM
white lightning SS's Avatar
pressure leak in the tank would lower fuel pressure, lean condition on accel, and would also would allow for pressure to bleed down and cause a long crank issue. These in-tank pump unit loose the pressure bleed back check valve in the pump all the time.
Old 02-26-2009, 02:01 PM
I learned something today. Gracias
Old 02-27-2009, 07:30 AM
PT's Slowest Truck
budhayes3's Avatar
If you're gettin an EVAP code and you're worried that it will effect the way the engine runs, it will not. The fuel pump sock is submerged in fuel...if there was a leak in one of the lines, not only would it possibly run lean, but you'd have a big fuel leak to show for it. Having the PCM pick up a leak for the EVAP system is kind of like running with the gas cap off (which is often the case with evap codes lol).
Old 02-27-2009, 07:50 AM
If you have an evap code 9 out of ten times it the vent valve mounted between the cab and the box. The solenoid opens in these. I didn't know if you were having an evap code or a lean running condition.
Old 02-27-2009, 01:35 PM
lpguy's Avatar
im having lean and evap codes, i was just wondering if they were connected or just 2 seperate problems... its not my gas cap they checked that when i tryed getting inspected, i guess something didnt get tightened all the way when the walbro got replaced...
Old 02-28-2009, 07:54 AM
PT's Slowest Truck
budhayes3's Avatar
Yea, I'll bet that they're both directly related to the Walbro replacement, check all of the lines and hoses, there may be a vacuum or fuel line leak somewhere...
Old 02-28-2009, 08:57 AM
DixieDevil's Avatar
check the middle line, after my walbro swap i got the same thing. there is a plastic t if you follow it, mine was snapped right at the t. just check all your lines... my .02
Quick Reply: quick stupid question
