quick rocker arm ?
Old Jun 12, 2009 | 11:17 AM
budhayes3's Avatar
PT's Slowest Truck
The Crane adjustable rockers seem like a nice upgrade, but very pricey, and may not be available due to Crane's recent demise...
Old Jun 12, 2009 | 04:34 PM
zapata41's Avatar
well i got a killer deal on them so couldnt pass it up.
now to runs the 918 springs or not is my next decision. they say that they can handle .600 lift but i dont know if i should risk them, or just pick up some double springs
Old Jun 12, 2009 | 08:28 PM
budhayes3's Avatar
PT's Slowest Truck
Go for the duals IMO...and if you do decide on a Beehive, get PAC springs...I've read too much about the 918's breaking, even the new silver ones
Old Jun 13, 2009 | 03:09 PM
zapata41's Avatar
yeah i have some older 918's and am not gonna push my luck with them. i heard the double springs are hard on valve train when compared to single springs
Old Jun 13, 2009 | 05:02 PM
cwalker2006's Avatar
i have some 1.75 adj. roller rockers if u havent purchased any yet. pm me if your interested.
Old Sep 15, 2009 | 09:38 PM
Matt G6007's Avatar
hey that guy was close but the lift is going to be 601/603 the difference in 1.7 to 1.8 is only 35*
Old Sep 17, 2009 | 09:51 PM
MikeGyver's Avatar
Hey, Matt, I think your calculator might have a stuck key or low batteries. blackbeast ss was correct in both lift and duration. How did you calculate lift? Assuming 35* in your post means 35 degrees, I think your thinking is very abstract.
Old Sep 17, 2009 | 11:03 PM
Matt G6007's Avatar
dude even if i am wrong its only 2* anyway but i dont think i am whats the equasion to figure it out???
ive seen them on two other motors they said it was only 35* difference...
Old Sep 17, 2009 | 11:24 PM
MikeGyver's Avatar
See post #2 in this thread.
When you say 35 with an asterisk (*), does the asterisk mean degrees? As blackbeast ss said, the duration does not change with different rocker arm ratios, if I am not mistaken. I am 97% sure that duration is measured at the lifter, not the valve. Maybe what you heard was "the same as 35° more duration" ?
Old Sep 19, 2009 | 06:58 AM
03 BLACKOUTSSS's Avatar
Duration will not change. That is a product of the cam lobe, as already stated. Teh lifter will still start and stop moving at the same point, leaving the duration the same, the 1.8 on the rocker will cause more lift only.
Wrecker 426
Oct 7, 2015 12:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
