quick Head tq spec help
Old Feb 20, 2011 | 03:33 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by viciousknid
yea I have a set on an engine I gave a friend for helping me do a swap. I'ma see if I can use them and buy him some more since his will be a while yet.
If I'm correct the only major thing between a 99 and 02 os is the injectors correct? So if i'm swapping to 02 injectors all I need to do is load up a regular 6.0 tune and then tune for the cam right?
There are other differences, but the only thing that would cause you to make a "mechanical" adjustment is the injectors...the 99's flow either 19 or 21# while 00-07 non-flex fuel flow 24.7# Yes, you are correct though, if you swap in the 02 injectors just upload the regular tune then work your magic from there.
Three6GMC
Aug 28, 2015 07:56 AM
DrX
Aug 19, 2015 04:45 PM
JordanH
Aug 8, 2015 07:59 PM
NuckenFuts
Jul 9, 2015 08:45 AM
