quick compression ratio question
Old Dec 4, 2010 | 11:35 PM
KozzyJr's Avatar
Default quick compression ratio question
whats the highest CR you can run safely on 91?
Old Dec 4, 2010 | 11:58 PM
budhayes3's Avatar
PT's Slowest Truck
It depends on a few things, basically where your dynamic compression ratio ends up. The bigger you go with the cam, the more compression that you can run without detonation. Tuning is obviously a factor, if you run less timing you can have more compression, keep it cool, etc. I wouldn't be afraid to run 11.5:1 with a big cam with a lot of overlap and a good tune...and I know that there are guys running around with over 12:1, not sure of their setups or what octane that they're running though...
Old Dec 5, 2010 | 12:26 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What is the method for calculating DCR?
Old Dec 5, 2010 | 02:48 AM
budhayes3's Avatar
PT's Slowest Truck
I'm familiar with some online calculators, such as this one: http://www.wallaceracing.com/dynamic-cr.php and I know that there are others that may be better? that have been posted in the Internal engine mod section. I used to use a different one, but somehow lost it when my buddy cleaned up my laptop (had a virus or something). I'm sure that someone has a formula around here too, but I'm not a fan of math
Old Dec 5, 2010 | 10:17 AM
tarinitup's Avatar
9 Second Truck Club
I did 11.0 with no problems using only 91 octane. Truck never had any knock retard and compression could have gone higher if needed.
Goat's ss
Jan 3, 2016 06:28 PM
03regcab sierra
Sep 9, 2015 02:02 PM
03sierraslt
Sep 6, 2015 06:53 PM
Three6GMC
Aug 28, 2015 07:56 AM
USMCvet0311
Aug 1, 2015 07:45 AM
