Pushrod length?
Old Jun 13, 2012 | 05:44 PM
Half-bred's Avatar
Default Pushrod length?
On the 02-04 z06 cam what lengh is the pushrod for that cam?
Old Jun 13, 2012 | 06:53 PM
Phantom's Avatar
11 Second Club
what heads? what length valve? which rockers?
a stock ls6 head with ls6 valve will use 7.400 pushrods.
a stock 5.3 head will use 7.425
Old Jun 13, 2012 | 09:25 PM
Half-bred's Avatar
317 heads stock valves and stock rockers
Old Jun 13, 2012 | 09:26 PM
Phantom's Avatar
11 Second Club
7.425 assuming the heads aren't milled and you're using stock lifters. not a bad idea to chck it out though
Old Jun 13, 2012 | 09:55 PM
Ferocity02's Avatar
I think 7.425 due to the smaller base circle. Search on LS1tech.
Old Jun 14, 2012 | 09:45 AM
Sales2@Texas-speed's Avatar
Former Vendor
7702-1 Comp Cams Adjustable Pushrod Checker
For sure get one of those for your toolbox!! You can get in the right ballpark as well by using a pushrod of known length and using the method of counting the number of rocker bolt turns from zero lash to 22ftlbs....but again, that is not the most accurate method.
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
bisqikss
Sep 8, 2015 03:35 AM
