PRC stage 2.5 5.3 heads or PRC stage 2.5 LS6 heads
Old Feb 28, 2012 | 03:34 PM
dmelvin's Avatar
Originally Posted by Matt@Texas-Speed
Remember the compression difference between the two is very small! We CNC port the 5.3L heads' chambers and they are about 63cc before any milling. The LS6 heads do not get a CNC chamber, and start right about 64cc. The major advantage of the LS6 is better port design and layout. Everything else equal, the LS6's will make better power!
how much more power over the 5.3 heads would you typically see on a cammed LS1?
Old Feb 28, 2012 | 07:31 PM
ccantu0389's Avatar
Thanks for the feedback. How much power in general if I was to go with the LS6 heads along with a cam swap.....say that the truck is running low 13s (13.2) in 1/4 mile, what do you think would be the new track times with these heads & cam swap? Just trying to get ideas.
Old Mar 1, 2012 | 05:12 PM
Sales2@Texas-speed's Avatar
Former Vendor
On an LS1 engine with quality bolt-ons, the 5.3L heads are typically worth about 35-40hp.
Old Mar 1, 2012 | 05:13 PM
Former Vendor
Depending on the short-block and bolt-ons, you can expect between 40 and 55hp from the LS6 heads over stock...some more than other, again, depending on what head was there before. Obviously the combo swapping over from the 317 truck heads will gain a bit more due to the compression bump AND porting gains, whereas the guys running a stock 5.3L or 241 head will not see as big of gains because the compression change isn't as significant.
Old Mar 1, 2012 | 07:32 PM
ccantu0389's Avatar
Well the heads I have now are the stock 243 heads. It's an 08 5.3 Sierra.....
I plan on doing a cam swap and maybe doing the head swap as well (still debating) but I'm curious to see what power gains can be accomplished and what new track times I would expect with this combo.
KyleW707
Jul 29, 2015 08:17 AM
steves86ta
Jul 28, 2015 10:21 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
askkmb
Jul 18, 2015 09:02 PM
Aboss
Jul 9, 2015 10:28 AM
