5.3 Cam
Old Dec 30, 2009 | 03:22 PM
eilax53's Avatar
Default 5.3 Cam
I have a 5.3 and want to change the cam. I have a question tho... Will I need to get new cam bearings if I put an LS6 cam into it?
Old Dec 30, 2009 | 05:02 PM
LS1TRUCKGUY's Avatar
no, but you will need a new flux capacitor....
but seriously, you will just need hardened push rods, and valve springs
Old Dec 30, 2009 | 05:17 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
everyone knows the flux cap is good to 3,000,000,000 miles
What he said, hardened pushrods and different springs to make use of your increased lift and higher revs.
Old Dec 30, 2009 | 05:27 PM
eilax53's Avatar
Can I do all of this without removing the heads? and I forgot that do i need new bearings if i get a used cam. Not sure since these are wear items
Old Dec 30, 2009 | 05:29 PM
trever1t's Avatar
yes, absolutely. there's a cam instal thread...somewhere here in the stickys.
Old Dec 30, 2009 | 05:38 PM
all this can be done without removing the heads. the bearings are fine. use the search function up top and you will find all the info you need
Old Dec 30, 2009 | 11:52 PM
guero68's Avatar
man if you asking about cam bearings and taking heads off by now with out searching this site..i would suggest gettting someone to do this for you.
Old Dec 31, 2009 | 11:37 AM
eilax53's Avatar
Sorry guys that I didnt use the search function...
Heres a link to show my level of expertise... I think i can handle a cam swap.
https://ls1tech.com/forums/conversio...wap-build.html
Old Dec 31, 2009 | 11:46 AM
00ChevyScott's Avatar
Wearin' da big hat
Swapping a stock 5.3 into an 84 vette.... You sure you don't wanna get someone to install it for you?
Old Dec 31, 2009 | 11:53 AM
charcoal03silvy's Avatar
He's saying he's done that before. So cam swap for him should be easy.
