porting 243's
Currently doing a some mild bowl blending on a set of 243's and am wondering if the swirl hump near the valve guide should be ground out and blended in? This will be a mild 6.0 build using a cam in the 218 intake duration range.
The only thing I would do myself would be polish out the exhaust runners, and grind the rocker arm bolt casting out of the intake runner. I have seen more harm than good done on these heads without a flow bench.....
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
lxcoupe
Sep 25, 2015 12:36 PM
