ported ls6 heads vs stock ls3 heads
Old Oct 2, 2013 | 01:10 AM
TURBHOE's Avatar
Default ported ls6 heads vs stock ls3 heads
i was just offered a pair of stock complete ls3 heads for $400. i was going to run my p&p ls6 heads on my 6L but it seems this might be a good deal. what do you guys think? are the heads worth $400 and would they flow better than my ported ls6 heads?
i understand i will need a new intake and all that good stuff. it is still turbo charged.
Old Oct 2, 2013 | 03:30 AM
TURBHOE's Avatar
what would make more power compression or flow? 320 vs 340 or 9.8:1 vs 10.4:1?
Old Oct 2, 2013 | 08:23 AM
BigKID's Avatar
What are the specs on your ported LS6 heads?
As to your second question, at those cr levels, I would opt for flow over compression on a turbo setup.
Old Oct 2, 2013 | 03:46 PM
99ta's Avatar
Do you think you might lose low end torque with the larger runners? It may not be that bad with your stall but, I would want all the bottom end I could get in a heavy AWD SUV.
Old Oct 2, 2013 | 04:35 PM
TURBHOE's Avatar
They are home ported heads And stock valves. A buddy of mine ported them for fun the had them flowed. They were over 320 at .600, he didn't need them any more and gave them to me. It's what I had on the 5.3 for a long time. When it went it only dinged up one cyl but not bad enough to hurt the heads.
Old Oct 2, 2013 | 06:59 PM
black00chev's Avatar
Slowest turbo build ever!
I would shoot more for the better CR. It will help over the whole power curve versus just the top end of a larger head. Besides, that's what the turbo is for.
The guys doing my cam swap have done turbo builds on several different LS cars and have had more success keeping the heads on the conservative side.
Old Oct 3, 2013 | 11:05 PM
TURBHOE's Avatar
i was kinda thinking the same thing. that and getting as much low end grunt to get this heavy mother moving is good. not to mention after adding it all up it would cost a good amount to convert over. between the tb, intake and x-link.
Old Oct 4, 2013 | 09:15 AM
ZO6Ted's Avatar
The exhaust on the LS3s are very limited without porting but if it lowers compression you could turn up the boost a bit. The turbo is gonna make the power anyway and its not like 9.8 is low but it probably would lose some low end due to larger ports of the LS3. Don't really think its worth all the trouble...not enough difference for all the hassle. Ported LS3s yes but not stock.
Old Oct 4, 2013 | 11:42 AM
slowswb's Avatar
I have ran advance induction ported 799 heads on my 6.0 and it made 435 hp now I'm running stock ls3 heads and car intake make 462 that with 24 degress of timming because I'm going to be spraying it soon.
Old Oct 4, 2013 | 11:47 AM
skeet's Avatar
same cam? anything other changes besides heads? that some pretty good numbers with the car intake the FAST car style should put you where or above where i was at up the timing to 30 with some br7ef plugs 93 octane and see an increase. <--- NA of course, i usually ran around 30-33* during daily driving NA, 408 i run 36* could run more but no need to
