Please help I'm lost
Old May 14, 2014 | 08:25 PM
Atomic's Avatar
I have a gauge for that
Yea compression and leakdown tests would be a good idea. And obviously make sure the crank and cam sensors are plugged in.
Old May 14, 2014 | 08:42 PM
TURBHOE's Avatar
Originally Posted by Atomic
Well, you could try swapping in known-good injectors with accompanying data and go from there. If it works with those you know its a fuel issue.
I've actually thought about putting my 60's back in just to see if it works.
post your tune and ill check out the data.
I'll try to do that. I'm having to use sons computer and it's slow as Christmas. Ever time you do something it says not responding and you have to wait. Lmao.
Originally Posted by AKlowriderZ71
Compression test will tell you if a valve is not closing due to having too long of pushrods. Which is entirely possible having had the block decked and the heads shaved.
Check the basics before you chase your tail too much.
I am planing in doing that stuff tomorrow. Seems odd to me to have the push rods be too long with just .008 removed total. But anything is possible. And it seems like I had a couple valves I watch move ever so slightly when I torqued the rockers. It seemed off at the time but I just figured I didn't have number 1 at perfect TDC. So I rotated everything and re torqued. However, I didn't break torque before I redid it. Just verified it.
Old May 14, 2014 | 08:50 PM
TURBHOE's Avatar
Originally Posted by Gadgetized
I had some problems with the air gap of the crank sensor. My block is a 99(I'm not sure what year yours is), and apparently they were a little closer to the reluctor wheel causing the sensor to hit causing false readings. Just a thought.
I used the stock crank and sensor out of the same block. Just changed the rods and pistons. I did find it kinda loose and dirty (the plug). So I cleaned it with maf cleaner and pushed it back on.
I have no CEL's either. Hell I can't even get the damn maf to fail for me, won't run long enough.
Old May 14, 2014 | 08:52 PM
TURBHOE's Avatar
Crank and cam were the first ones I checked lol. The cam and oil sensor were the first things I plugged in.
Fuel press is a solid 58 btw.
Old May 14, 2014 | 09:58 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
For the love of Pete, WHY are you still running a MAF?!?
Old May 14, 2014 | 10:16 PM
TURBHOE's Avatar
I'm not. Haven't been for a very long time. But the maf has to fail even with 2bar os. When the tune is dead nuts on you won't notice it after a flash tune. But if it's off a little it will run like **** for about 30 seconds until the maf fails then it's good to go.
Old May 14, 2014 | 10:23 PM
BlackGMC's Avatar
Resident Retard
Interesting. My maf has been sitting on the shelf in a box for years and i have never had that issue.
Old May 14, 2014 | 10:53 PM
TURBHOE's Avatar
It only does it when I clear codes or load a tune. With the stock cam or small cam you can't even notice it. But with cams bigger than ls6 it starts to get noticeable if the tune is off. But like I said it only take about 30 seconds to fail the. It's good to go. I cut out almost the entire run of maf wire from my harness and shortened the iat sensor wire by like 3'. Looks way better with out all that crap in there.
Old May 14, 2014 | 10:57 PM
TURBHOE's Avatar
Windows computer suck so bad. My sons computer did an update now Internet explorer won't work. I'm trying to fix it so I can post the tune.
Old May 14, 2014 | 11:09 PM
TURBHOE's Avatar
here is the tune. hope it works, i put it on a thumb drive and loaded it with my macbook. don't mind the ve table its all out of wack trying to get this thing started.
File Type: hpt
