Piston Squirter....
Old Apr 7, 2009 | 09:48 PM
  #21
L7 Sierra's Avatar
What about windage induced by the oil squiters?
Or is enough durability gained to offset windage losses?
I used to add windage trays to my sbc's religously to get the free hp.
Old Apr 7, 2009 | 10:03 PM
  #22
Just Enough's Avatar
Originally Posted by Wilde Racing
Brian nutter works for wiseco, I would want to check with him to make sure there would not be any problems usingbthe squirters with my currant pistons.. And yes the engine would be comming back out and apart
If your pistons are really made of raisins as you stated above, you really need the squirterers. How often do you need to refill them?
Old Apr 8, 2009 | 08:33 AM
  #23
On a more serious note, you probably will need a higher volume oil pump than stock, like a Melling. Send Jason Harding at Katech an e-mail and see what galley modifications need to be done and what pump they recommend. Some of the heavy breathing Corvette LS3s have had the squirter mod done.
Old Apr 8, 2009 | 10:24 PM
  #24
AdioSS's Avatar
12 Second Club
I was wondering why you would call somebody that works at Wiseco, but that makes sense. Some pistons built for engines with squirters have a notch in the skirt otherwise the piston and the squirter might try to occupy the same place at the same time.
Old Apr 8, 2009 | 10:31 PM
  #25
2004SSS's Avatar
this would be a good idea for my tt lsx. just need to make sure they will work with that block . any contact info for the guy a katech?
Old Apr 8, 2009 | 10:44 PM
  #26
Wilde Racing's Avatar
How do I change this text
I sent a email to Jason, and a link to this thread....
Old Apr 8, 2009 | 11:04 PM
  #27
2004SSS's Avatar
cool , hopefully he will let us know . any idea on cost for a setup?
Old Apr 9, 2009 | 07:47 AM
  #28
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by Bill Reid
I think I remember reading about these first in the Soltice Turbo motor... before the LS9. Not sure if thats right but it sure does sound like it might be a good option if scratch building a motor... squirters aren't too bad in price from Katech... just wonder what the machine work cost is. "Cool" stuff
We charge $159. Not a bad price in my opinion.
Originally Posted by 1Bear
I would imagine one would also need the higher capacity oil pump from the LS9 to cope with the controlled oil leak that would be introduced.
We were cautious to recommend this at first, but recent testing has shown that the LS7 pump can keep up just fine. The piston squirters have a check valve in them to turn them off at low rpm.
$400 for a set of squirters
$159 for block machining
Old Apr 9, 2009 | 01:49 PM
  #29
vanillagorilla's Avatar
The LS7 pump is a for a dry sump setup, as is the LS9. Have you guys tested the on the regular crank driven style pumps (LS6, melling HV, etc.)? Switching to a dry sump to run these would be a PITA IMO.
Besides you only need one for cyliner #7.
Old Apr 9, 2009 | 01:54 PM
  #30
LS1TECH Sponsor
LS7 and LS9 are gerotor pumps driven off the front of the crank just like every other LS engine. We have not tested the piston squirters with any wet sump oil pumps.
