piston ring gap
Old Dec 20, 2006 | 10:51 AM
Tootall's Avatar
Default piston ring gap
Where can I read up about setting the gap? If you order new pistons with rings, are they pre-gapped? These are going in a stock motor.
Old Dec 20, 2006 | 11:09 AM
TurboGibbs's Avatar
If you are running a stock engine then yes, just order rings for the bore size and install them. I'd always check the gap first just in case but they should be fine. File fit rings come larger and are often designated as +5 at the end of the part# or if you have a 4.030 bore a file fit ring will say for a 4.035 bore.
Old Dec 20, 2006 | 01:03 PM
Tootall's Avatar
great, thanks
OHsixLS3
Nov 22, 2015 07:45 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trxmxzx
Sep 29, 2015 07:42 AM
