piston ring gap
If you are running a stock engine then yes, just order rings for the bore size and install them. I'd always check the gap first just in case but they should be fine. File fit rings come larger and are often designated as +5 at the end of the part# or if you have a 4.030 bore a file fit ring will say for a 4.035 bore.
lukn4trbl355
Oct 21, 2015 11:19 PM
