PG Dual springs or Comp 918s?
Old Jun 12, 2006 | 03:41 PM
nightmarechevy's Avatar
Default PG Dual springs or Comp 918s?
I just got a set of NIB Patriot Gold dual valve spring complete with the entire kit and have read on here and been told by others that I will have to change them out fairly often. Should I just go with Comp 918s and sell the duals? I want something that I will not have to change out or check once they are installed.
Old Jun 12, 2006 | 04:35 PM
ZR1 DREAMING's Avatar
In order to help you with your question you need to post your cam specs
Old Jun 12, 2006 | 05:26 PM
black4.8's Avatar
any cam under .600 lift the 918's are fine. lot of guy's run em & i don't here of anyone complaining.
Old Jun 12, 2006 | 06:15 PM
224/224 581/581 114
Old Jun 12, 2006 | 06:17 PM
I already have the Patriot Golds. My question is should I keep them or sell them and get 918s?
Old Jun 12, 2006 | 06:53 PM
Rhino79's Avatar
9 Second Club
I would keep them, they surely would last longer than the 918's. Your cam is pretty close to the .600" lift max for the 918's so I would reccomend a dual spring anyway.
Old Jun 12, 2006 | 06:58 PM
I'm running Comp 978s,the guys at TEA said that's the only valve spring they've never had a failure with.
Old Jun 13, 2006 | 06:50 AM
black4.8's Avatar
if you already have them u might as well use them. dual springs r better than a single any day. u would be pushing the limits of the 918's w/that cam. BTW great cam choice. when is the big install day? good luck with it.
Old Jun 13, 2006 | 07:29 AM
As soon as the stall gets here I will tear it apart and start the install. I'm going to do the cam, springs, chromemoly pushrods, underdrive pulleys, and 3400 Fuddle stall. The stall should ship out Wed, everything else is already here.
Old Jun 13, 2006 | 01:13 PM
black4.8's Avatar
that thing is going to be pretty healthy. should run damn good.
