Parts list opinion
Old Aug 25, 2014 | 03:00 PM
Nilla's Avatar
Default Parts list opinion
Hey guys I'm just looking at some opinions for my parts list, Its for my 5.3 that I got out of a 02 gmc yukon that was rolled over, supposedly has 140k miles. I talked to a shop and told them this is going into my 1980 swb C10 that weighs roughly 4500lbs, has a 5 speed and 3.73 rear gears. I told them I don't care for mileage and that the only other modifications that this 5.3 will have is going to be long tube headers and a hot air intake. They recommended a 226/228 .585/.588 114+4 camshaft with BTR .660 lift dual springs and Tool steel retainers. As well as possibly lifters if its a higher mileage motor. So from that I built this list so far
Camshaft- 226/228 .585/.588 114+4
BTR .660 lift dual spring kit with tool steel retainers
5/16" 7.400 Hardened Pushrods
LS7 Lifter Kit
Melling Hi Volume Oil Pump
GM LS2 Timing Chain
ARP LS1/LS6 Hex Head Bolt Kit
Stock 5.3 head gaskets
What other necessary gaskets should I replace? (intake, timing cover etc?) any of those necessary to replace?
Old Aug 26, 2014 | 10:46 AM
turboal1's Avatar
Default gaskets
yes, timing, intake and water pump. any thing you take apart
is a potential leak if you use old gaskets. no need to do a job twice.
Old Aug 26, 2014 | 07:27 PM
Nilla's Avatar
Okay i'll have to add that to the list, what do you guys think about the cam?
Old Aug 27, 2014 | 12:24 AM
1ownerCHEVY's Avatar
I think it should do nicely with your setup. Especially being m5. Nice parts list btw, should make for a reliable, proven valve train.
+1 on gaskets, cheap insurance.. also oil pick up tube o-oring (orange)
What heads you running?
Old Sep 1, 2014 | 01:29 PM
Tim94gt's Avatar
12 Second Club
Don't forget new lifter trays...
Old Sep 1, 2014 | 02:10 PM
BIGDADDY1969's Avatar
Cool
How will that 5.3 bolt up to the 5 speed? Or is the 5 speed out of nbs like the 5.3 was?
03chevytruck
Nov 7, 2016 04:43 PM
5.3Caprice
Nov 7, 2015 08:56 PM
2500ZL1
Aug 14, 2015 12:23 AM
Aboss
Jul 9, 2015 10:28 AM
Mzay
Jul 6, 2015 11:05 PM
