opinions on a cam setup for 5.3L
i've been reading about cams lately and i am wondering if this is the best setup for my goals. i have all mods in sig.this is a daily driver and cam and 100 wet nitrous is as far as i want to go with this motor.
i like the sound of a cam, so that is not a problem, but would this be too much for daily driving?
would i be getting the max performance out of this setup or do i need more supporting mods?
the 100 wet shot will come in the future, should this affect cam choice?
what would i be running in the quarter w/o nitrous with this setup?
what rpm should i be shifting at?
tr224
Thunder Racing Custom Camshaft - 224/224 .563/.563 112 LSA 1700-6600 RPM Power Band. Excellent mid-range & high RPM power. Requires computer tuning on automatic transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
comp 918 springs
thunder racing hardened pushrods
fuddle racing 3000rpm torque converter
transgo 4l60E shift kit (user install, not the hd2 kit)
comes out to be like $1200
is that reasonable?
how much should i expect for installation?
thanks for you opinions
jerome
tr224
comp 918 springs
is that reasonable?
jerome
Id expect you to run low 13's with that setup. If thats what your after you on the right path. There are more n20 friendly cams out there though I think the 224 is more of an NA cam. If you take the heads off do a valve job its well worth it.
with a 3000 stall cruising on the freeway, would rpm's always be above 3000?
any opinions on if shorty headers, stock pipes, and a magnaflow muffler good enough flow to support a cam like this?
a n2o friendly cam would be one with more exhuast duration? so would this be good?
Thunder Racing Custom Split Pattern Camshaft for Nitrous/Supercharger applications- 224/227 .563/.569 114 LSA (This cam will check in the 226 range on the exhaust lobe.) 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Automatic cars require computer tuning and it is recommend for optimum results on manual transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
and by low 13's, you mean with the spray right? cause right now i'm running 16's
thanks
thanks
yes with the spray. By n20 friendly I mean less overlap give futral or LPE a call. Cruising highway speeds stay about the same its only when the converter is unlocked that it stalls alot higher. I have the same gears and stock tire height at 80mph with a 3k stall its around 2200 rpms.
Without stage 1 and up heads I think a cam over 224 duration is a waste on a 5.3 but thats me.
The stall has nothing to do with freeway RPMs, since your converter is locked up at steady speeds. The determinants of freeway RPMs are your (1) transmission gearing, (2) rear end gears, and (3) tire diameter. Whatever your freeway RPMs are now is what they will be after your cam and TC install.
Many people like the 212/218 from Comp. You could also fill in the Cam Request form at Cam Motion with the details of what you are after, and see what they say. That's how I ended up with my cam, and I am very pleased.
Im am also installing a 212/218 comp in my truck, hope to get some good results.... I will have the stock converter for a while, but hopefully I can get the TB converter by Jan...???
