opinions on cam needed
Old Feb 4, 2011 | 09:06 PM
02gmcbandit's Avatar
Default opinions on cam needed
i know theres a thread about how much lift is ok for a 5.3 but i cant seem to find it. wanting yalls opinion on a cam im looking at at texas-speed. specs are 233/239, .595"/.603", 112 LSA
Old Feb 4, 2011 | 09:08 PM
Atomic's Avatar
I have a gauge for that
No point in going with big lift on stockish heads. .600 lift is more than adequate.
Old Feb 4, 2011 | 09:19 PM
well after the cam or either with the cam im going to get some 243's or texas-speed's 2.5 heads. i may get the cam first and then get heads later, or if i can find a set of 243's for a good price i may pick them up too. i've read theyre proven , but cant always believe what you read thats why i posted asked first before i spend money.
specs on 2.5's are 2.02" Intake Valves, 1.575" Exhaust Valves, cant remember on the 243's. last cam i bought i didnt install cause my tuner said it didnt have much lift, it was a 226/229, .569/.572, 112 LSA
Old Feb 4, 2011 | 09:20 PM
i'm only wanting to go with around a 3200 stall also so not sure about how well it would work with the high lift
Old Feb 4, 2011 | 09:42 PM
53bowtie's Avatar
stalls have more to do with duration than lift I believe. That cam you have there has quite a bit of duration for a 5.3 and I would think you would want to go bigger than a 3200 stall. That looks like a pretty good cam for a 6.0 IMO. There are plenty of cams with around .600 lift so that is not too uncommon. Every one of EPS's truck torque cams have around a .600 lift. In short I would be worried about the duration more than the lift.
Old Feb 4, 2011 | 09:44 PM
1slowz71's Avatar
i believe that less is more when it comes to cams , i would say for a 5.3 a
217/223 or around that duration on a 600 lift is more then enough ! just my 2cents , but iam no expert!
Old Feb 4, 2011 | 10:00 PM
grey matter 04's Avatar
13 Second Truck Club
Exactly !!
I run a small cam 212/218 with 529 lift
my truck will run with the best of them even if they have more camshaft
Old Feb 4, 2011 | 10:01 PM
budhayes3's Avatar
PT's Slowest Truck
You sir are correct, as the duration increases, the powerband moves up. A cam that big in a 5.3 is going to need a ton of converter and gear...I'd say a 4k plus converter, 4.56's or more, and extensive tuning. We have members here who run 12's with a 5.3 and a TR220, 4.10 gears, 3200ish converter (IIRC), and stock heads. As 1slowz71 mentioned, sometimes less is more
Old Feb 4, 2011 | 10:19 PM
StrokerAce03's Avatar
BlueCajun ran a 12.48 I think it was with a TR220 and a Yank SS3600. For a 3200-ish stall I'd run a low duration high lift cam made for torque, for the cam you listed I'd run at least a 4000 although personally I'd run more.
Old Feb 4, 2011 | 10:29 PM
dmelvin's Avatar
Originally Posted by grey matter 04
Exactly !!
I'm gonna go with the bigger brother of his cam, the 216/220 .. since I'm in a reg cab, I should have a really similar result as him
I'm also going with milled 243's which should help a little bit too, along with LT's
