oil pump and rockers?
Old Apr 13, 2009 | 05:30 AM
05crew's Avatar
Default oil pump and rockers?
im going to get a new oil pump for my 408...is Stock ok to put back? or is there a better one out there. and rockers....who makes a good set...does anyone run
Scorpions?
Old Apr 14, 2009 | 06:51 AM
white lightning SS's Avatar
Katech ported and modified oil pump is the best available IMO. Harland Sharp bolt ons are very nice pieces. Ajustable rockers are a pain ijn the a$$ and you need valve cover spacers or a lot of custom clearancing.
Old Apr 14, 2009 | 11:36 AM
budhayes3's Avatar
PT's Slowest Truck
I have Harland Sharp 1.7's on my truck with 15k on them that I will be selling if you're interested...
Old Jul 12, 2009 | 10:54 AM
TURBHOE's Avatar
is there any difference between the ls6 pump and a stock truck pump?
Old Jul 12, 2009 | 11:28 AM
hirdlej's Avatar
This is my favorite gm pump here. http://www.lingenfelter.com/mm5/merc...egory_Code=C54
It's just like the melling pump but designed by gm. I used the low pressure relief spring in mine. 45psi hot idle and by 2K rpm's it's 60 psi, anything 3K or higher is 80psi. No shortage of oil pressure and I never have sucked the pan dry. I run it hard too......
Old Jul 12, 2009 | 11:36 AM
supersub's Avatar
Same one i run as well, An excellent pump!
Old Jul 12, 2009 | 09:50 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, I've always liked the Lingenfelter pump. So you cracked it open and swapped out the spring for the standard pressure spring that was supplied with it?
Old Jul 12, 2009 | 10:05 PM
hirdlej's Avatar
Yup, I took the red one out and put the white one in that was supplied with the kit. The kit also comes with the truck o-ring
Old Jul 12, 2009 | 10:12 PM
zippy's Avatar
The stock one is fine, but on a 408 you may end up with a bit less oil pressure. I recomend a stock oil pump from a D.O.D. motor. They have great pressure and more volume than the ported standard style pumps.
As for rockers I'd only recomend Yella Terra's if you don't run the stock one's.
Old Jul 12, 2009 | 11:21 PM
TURBHOE's Avatar
the dod pumps will work on my 5.3L?
