oil pump
Old May 5, 2014 | 09:26 PM
tim wellington's Avatar
Default oil pump
any one switch to high volume pump after there build .chevy has one in summit for 80 bucks. thoughts
Old May 6, 2014 | 10:02 AM
Gadgetized's Avatar
I didn't, but I wish I did. I will for my next build. I think the oil flowing through the turbo so fast has lowered my oil pressure a little bit. If I tear the engine apart to inspect things I will get one then.
Old May 6, 2014 | 11:12 AM
Default oil pump
thanks for feed back .thats what i was thinking about .i am using ls7 lifters.I heard ls7 enginge come with a high volume pump.
Old May 6, 2014 | 11:28 AM
Ferocity02's Avatar
I believe the LS7 pump is a completely different design than the other LS pumps. I went with a Melling pump and ported it slightly, plenty of pressure even with the turbo.
Old May 6, 2014 | 01:53 PM
Txblue's Avatar
Yeah the ls7 pump is completely different. They are a dry sump.(dret is what people call it for dry/wet) because its kinda a mix if both.
Old May 6, 2014 | 03:19 PM
Thumbs up oil pump
i know its a dry sump.pumps made totally different .i was saying its high volume pump as far as oil delivery.
Old May 6, 2014 | 07:19 PM
oakley6575's Avatar
I went with a high volume/high pressure pump from melling just because it was sitting on my shelf for a camaro that I never did. I threw it in the 4.8L when I went turbo and it is a badass pump for sure. I don't have a cooler on it yet but I get 50psi hot, 60psi cold and 100+psi at WOT
pupi305
Sep 14, 2015 11:40 AM
Tigger Welder
Sep 2, 2015 08:17 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
