Oil pressure sensor
Old Jun 15, 2020 | 11:17 AM
Guesswho713's Avatar
Registered User
Default Oil pressure sensor
I'm having an issue with my lq9,in the past year I've had 3 oil pressure sensor's fail at wot what can be causing this it's a simple n/a build.I was using 20-40 oil but a buddy suggested I go with a 10-40 could the oil have been the issue..
Old Jun 15, 2020 | 11:35 AM
arthursc2's Avatar
Doubt its the oil weight
Are they OE sensors? How are they failing? How are you installing them, and to what torque value?
Old Jun 15, 2020 | 11:43 AM
Registered User
[QUOTE=arthursc2;5484402]Doubt its the oil weight
Are they OE sensors? How are they failing? How are you installing them, and to what torque value? Bith have been parts store so not OEM,and they fail at WOT..
Old Jun 15, 2020 | 11:44 AM
Registered User
Are they OE sensors? How are they failing? How are you installing them, and to what torque value? Both have been parts store so not OEM,and they fail at WOT..
Old Jun 15, 2020 | 12:54 PM
arthursc2's Avatar
I'd start with an OE sensor, installed with the appropriate socket and 15 ft/lbs. The spec might be 17lbs, I will look for you tonight. Make sure the linked sensor is appropriate for you application
Amazon Amazon
https://www.rockauto.com/en/moreinfo...%2F8Gpw30Q0JRh
Old Jun 15, 2020 | 02:03 PM
RedXray's Avatar
100% Redneck
Buy the AC Delco sensor and the sensor socket to install. My LQ9 with a two year old Delco oil sensor sees 6600 RPM quite often running Mobile 1 0W-40 Euro (highest ZZDP non racing oil)
Old Jun 16, 2020 | 08:19 AM
terravast4's Avatar
When my motor was fresh my delco sensor failed after the very first oil change. I replaced it with another brand from O’rileys that was brass. Seemed better quality than the aluminum delco part. I was running Amsoil 10-40 and switched to 0-40 since.
sierraboy
Aug 28, 2012 08:32 PM
slow.8
May 23, 2012 07:16 AM
4.8chevysilverado07
Feb 22, 2012 12:44 PM
DoubleTrouble
Jun 6, 2011 02:47 AM
Mort
11
Jul 29, 2008 09:50 PM
