new vortec heads
so far on my 98 vortec 350 in my sierra i have bolted on Thorley tri-y headers, k&n filter, full flowmaster true dual with 2.5in tubing and a 160 degree thermo... im looking for power beyond the bolt-ons. My question is should i stick with the cast iron vortec heads but port and polish them, or should i opt for the fully assembled aluminum Edelbrock E-tec 170cc heads, or the same Edelbrock heads in the 200cc version? I will of course change the port match the intake manifold and get a new cam and lifters which i will probably need help with later to match... but stick with the cylinder head question for now... any comments will help!
These are nice heads as well. The GMPP Bowtie Vortec smallport heads
http://www.sdpc2000.com/catalog/3129...inder-Head.htm
peace
Hog
peace
Hog
instead of the marine intake manifold could i use an aftermarket manifold from edelbrock or somewhere thats made for my engine already or do i need all those parts? is the marine intake, adapter and all that stuff i need to keep it efi manditory? sorry... im a lil new at engine mods. and what do u mean clean up the heads without pocket porting?
As far as cleaning up goes, I mean do a normal valve job, you hot tanking etc, normal cylinder head rebuilding stuff. They don't make an intake manifold for our engines that just bolts on and still retains all our efi stuff. You could go carbed if you wanted, or buy the carbed intake, use that elbow adapter, buy the new injectors, and you would then need to rewire your injector harness to plug into your factory one. There is ALOT of info on the pacificp website. You could use a smaller cam, and get some HP out of the factory intake and injectors, but if your looking to make alot of HP your gonna have to do something with that factory EFI setup, because it sucks and you can't upgrade injectors
could i use one of these intake manifolds with that intake adapter elbow u mentioned? since its made to fit my truck would i need the elbow?
http://store.summitracing.com/partde...&N=700+150+150
or...
http://store.summitracing.com/partde...5&autoview=sku
or...
and i can get it tapped for injectors and all that at a local machine/engine shop? what rails and injectors do u recommend? would i have to do nething to my electronics or any wires or is it all just basic bolt up?
so i can send my manifold to them instead and theyll do all the work for me... but what besides the EFI intake conversion job would i need to get from them? just the fuel rails? will i need to modify my wiring harnesses or any electronics and will i need new injectors?
(whew... lot of questions... sorry)
From them you will want to send teh intake you get to them and have it converted for EFI, purchase the intake elbow adapter, and fuel rails from them. You will then need to purchase injectors from somewhere (I'd look around here for some good stock injectors off the LS1's). You will need to do some wiring to hook up the new injectors and also run new fuel line to your factory lines, oh and a fuel pressure regulator. It's alot of work man. How much power are you looking to make?
