New guy needing help with '99 5.3l
Old Nov 10, 2011 | 11:31 PM
dmelvin's Avatar
Originally Posted by JL_Mullen
If I go with atomic's suggestion using the 212/218 cam with ls6 springs and the stock converter, will that make my bottom end rpm range sluggish?
I wouldn't think so. I had a 216/220 cam with LS6 springs with the stock stall for a couple weeks and the thing felt great everywhere.
jrmchevyman's Avatar
Everybody has different preferences, since yours is an EXT cam it weighs more. It should be okay, what is your gears and tire size also? The 212/218 isn't a huge cam by any means, but even a good 2800Rpm converter would make a lot of difference later on down the road.
You can always get the cam now, and if you aren't real happy then save up for a ~$400 converter.
Old Nov 14, 2011 | 06:05 PM
CSpencer04's Avatar
•Advertised Duration (Int/Exh): 262/268
•Duration @ .050 (Int/Exh): 212/218
•Gross Valve Lift (Int/Exh): .531"/.531"
•LSA/ICL: 113/109
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1400-6200
•Includes: Cam Only
Part Number: 60510
lunati voodoo I have in my truck used the springs lunati recommended runs great with stock converter but I can tell it needs tuned. It will still **** and get compared to stock though lol. Really wakes it up all over the rpm range.
Old Nov 18, 2011 | 02:01 PM
1FastBrick's Avatar
Custm2500's Rude Friend
No. It loses no tourque down low. picks up through the mid and upper RPM its a good all around recomendation.
Old Nov 18, 2011 | 07:10 PM
Slammed96's Avatar
I have this exact cam in my ex cab 4.8 and it runs superb. Good power throughout, but really starts pulling around 2500+rpm. It will not like to idle in gear very well before you tune it though, so if you end up getting it, make sure a tune arrives soon after. Also welcome to PT
Old Nov 23, 2011 | 10:30 AM
azchevydude's Avatar
Slammed,
I have an 01 ECSB with 4.8. If one was to go with this cam set up what would you do for heads?
Go5.3tt06
Sep 12, 2015 09:29 AM
GM-only
Jul 19, 2015 10:48 PM
Aboss
Jul 9, 2015 10:28 AM
ALynch
Jul 6, 2015 09:49 AM
