Needing help on a cam: Opinions needed
Old Aug 14, 2013 | 06:09 AM
ski7541's Avatar
Smile Needing help on a cam: Opinions needed
Ladies and Gents,
I came here to ask opinions about some upgrades I plan on doing to my truck:
About the truck. It's a 2004 CCSB with 80k on the clock, It has, 3.73 gears truetrac, LT headers, 4l60e w/shift kit,servo, 212/218 cam for now and 706 heads.
Now what I'm going to do is put some 243/799 heads, 2800 or 3000 stall and A 224/224 or a 228/228 cam.
Truck will be a daily driver and tow a travel trailer sometimes...
Now what I wanting opinions on is which cam would you suggest? How much would you mill the heads? and which stall (RPM) would you run?
Old Aug 14, 2013 | 09:35 AM
Whitecrewcab's Avatar
If it was me, I'd mill the heads and put a thinner head gasket in to keep the compression up and leave the 212/218 cam in it. I have a 218/224 in mine and you can feel the bottom end difference from a smaller cam. I have a 9.5" Vigilante that stalls right at 3000 and it really could use another 800rpm or so.
Old Aug 14, 2013 | 12:33 PM
kelsey_canard's Avatar
X2. You need as much compression as you can get. If you are set on a 3000 stall, then I'd keep the cam you have. If not you will need more than a 3k stall for the other choice of cams, IMO.
Old Aug 14, 2013 | 01:15 PM
Camin00's Avatar
X3 lol the cam you have is perfect for lowend tq and midrange power = great dd and tower. Plus the crew cab is heavier compared to a single cab, you will need more tq and gear to get its big *** moving. The cams you listed for future swap would be better for a toy/weekend drive, especially in the small 5.3L bore.
Old Aug 14, 2013 | 01:18 PM
Camin00's Avatar
A lot of people on the form and a few machine shops I have talked to dont recommend milling more than .03 off the ls heads. For the money you are going to dump in the heads and cam I would just look for a LQ4 or LQ9 $800-$2000 and stick the 212/218 in it. That would give you more tq and top end power over the 5.3L
Old Aug 14, 2013 | 03:40 PM
grey matter 04's Avatar
13 Second Truck Club
keep the 212/218 and go for a 3k stall then head work..mill the 706s .040 and upgrade to the larger 2.0 intake valve
I did a set like this for under $350 with a performance valve job n other work.
sold them before i could run them but the truck they are on runs good
Old Aug 15, 2013 | 03:46 PM
Camin00's Avatar
grey matter was the $350 on the heads for machine labor and valves, or just labor?
Old Aug 15, 2013 | 09:20 PM
Everything but valves
Robbed some valves from a old set of ls1 heads
Old Aug 15, 2013 | 09:40 PM
trxmxzx's Avatar
did mine .035 off for 100 bucks at a local autovalue 7 years ago. only issue i could see is intake fitment. mine was tight but i think .042 is the most you can do and not give yourself a headache with intake.
my tr 220 on 112lsa with milled heads does awesome i wouldnt go bigger so imo stay with your cam- if my truck was heavier id downsize in cam.
Old Aug 17, 2013 | 08:25 PM
Blackpanther99's Avatar
As mentioned... Mill them heads and stick with that cam.
