need torqe spec for arp bolts in stock rods.
Old Jun 17, 2011 | 09:55 AM
TXsilverado's Avatar
Originally Posted by bigboy576103
I under stand the concept here but wheres the rpm point that i need to add the bolts.
Everything on my motor is capable of 7k except for the short block. I didnt plan to run it past 6500 but i really wont know until i drive it and see hoe it feels.
your short block is capible of going past 6500. but 6500 is a safe zone for stockers.
Old Jun 17, 2011 | 09:59 AM
Originally Posted by Coban
Did you find out what made the rod shatter? It wasn't because the rod bolts stretched, was it?
it was an old motor that was abused it's entire life lol. i'm surpriesd it ran that long and ran that good! my buddy that had it before me had a ms4 with a 200 shot spinning to 7k from 20,000 miles when he got the car...i got the motor at 120,000 miles for $275 and spun it to 69-7300 up to 150-160,000 miles. it also had countless bottles through it.
the rod end was still intact and the bolts were perfectly fine.
Old Jun 17, 2011 | 10:01 AM
^^ya but i know but seeing how tha bearing tolerances have already been set in from factory form, to where if i were to retorque them to arps it will make it oval shaped..( i believe!thats y im here for experienced advice lol)
Any more tips out there??
i would save the bolts for a fresh build IMO. 6500 is a safe RPM for these engines...do a search on broken rod bolts or engine failure due to rod bolts and tell us what you find.
Old Jun 17, 2011 | 10:45 AM
bigboy576103's Avatar
To much work haha jk. I believe ya. Im gotta try n get everything back together so i can drop it in next week
Old Jun 17, 2011 | 11:31 AM
WICKEDOWESIX's Avatar
Also when and if you do ARP bolts you will need to hone the rod big end as the ARP bolts clamp down with more pressure causing the rod big end to become out of round.
Old Jun 17, 2011 | 12:51 PM
00buckshot's Avatar
I have done it and had great results, no problems with mine, no re-sizing or anything
Old Jun 17, 2011 | 03:59 PM
lots of guys have great results. a few people have spun bearings after.
i know the ARP bolt is superrior, but why risk the small chance of a spun spun rod bearing if there is not a huge failure rate of the stock bolts to 6500rpm (or a failure at all that i know of)
Old Jun 17, 2011 | 11:33 PM
Sinistersilverado's Avatar
to answer your question, torque the arp bolts 40 ft lbs. i just installed some and the instructions said to do 40 so i went with what it said.
Old Jun 18, 2011 | 01:33 AM
black04's Avatar
I've read too many horror stories on tech about them.
Old Jul 17, 2011 | 04:57 PM
chevysten's Avatar
I changed mine too about 16k miles and no problems.I hammer down on it pretty hard with a 100 shot.You'll be ok.
