need torqe spec for arp bolts in stock rods.
Old Jun 16, 2011 | 05:07 PM
bigboy576103's Avatar
Default need torqe spec for arp bolts in stock rods.
Im putting arp 2000 bolts in my stock rods for security and was wondering what is recogmended for tightening these.
Tryinging to do these today
Thanks in advance
Ray
TXsilverado's Avatar
what's wrong with stock rod bolts? or a better question. how many trucks have you seen on this forum actually break a stock rod bolt? i cant think of 1. i can however get on tech and find a few cars that spin a rod bearings 1,500 miles or less after upgrading to new rod bolts.
the way i look at it, if it is a fresh motor being built, go ahead and upgrade the rod bolts. after the motor has some miles on it and everything is settled, leave it alone! everything is already sitting where it wants to be and any minor adjustments is enough unlodge some stuff you dont want unlodged...i spun a 150,000 mile ls1 past 7k for years before it broke. i shattered a rod.
but the rod bolts were still in there just fine! hell, it was a 99model LS1 engine with the "weaker" rod bolts than they use in todays LS engines.
Old Jun 16, 2011 | 05:19 PM
True but i was jus thinkin bout extra security under boost. Ive heard other guys doing this and not having a prob. With u saying that im opnen for opinions lol
Thanks for the respons stew
Old Jun 16, 2011 | 05:23 PM
joeyc125's Avatar
11 Second Truck Club
Power has nothing to do with rod bolts, only rpm. Power pushes the rod onto the crank, only rpm pulls it away if that makes sense to you.
Old Jun 16, 2011 | 05:32 PM
fastrt's Avatar
I did mine. no problems. I only did mine for rpm reasons.
Old Jun 16, 2011 | 05:44 PM
I under stand the concept here but wheres the rpm point that i need to add the bolts.
Everything on my motor is capable of 7k except for the short block. I didnt plan to run it past 6500 but i really wont know until i drive it and see hoe it feels.
Old Jun 16, 2011 | 07:16 PM
1989k1500's Avatar
So is the short block.
I know a bunch of people that spin them up to 68-7200 with no probs on stock rod bolts.
Old Jun 16, 2011 | 07:19 PM
Coban's Avatar
Did you not check ARP's website?
It would probably be a good idea.....
Old Jun 16, 2011 | 07:24 PM
Coban's Avatar
It's not about breaking, its about stretching... Higher tensile strength bolts resists this.
I spun a 150,000 mile ls1 past 7k for years before it broke. i shattered a rod.
Did you find out what made the rod shatter? It wasn't because the rod bolts stretched, was it?
Old Jun 16, 2011 | 07:28 PM
^^ya but i know but seeing how tha bearing tolerances have already been set in from factory form, to where if i were to retorque them to arps it will make it oval shaped..( i believe!thats y im here for experienced advice lol)
Any more tips out there??
