need ideas!
Old Oct 15, 2009 | 10:06 PM
sierra69's Avatar
Default need ideas!
need ideas on how to build this 6.0l out of a 2002 3/4 ton for my 2007 n/b cc sierra 4x2? i will do some towing and a little hot rodding. i read of a 408 stroker kit for the 6.ol? am i going the right direction for what i want? oh! buy the way i got the motor for free!
Old Oct 15, 2009 | 10:08 PM
charcoal03silvy's Avatar
Nice job on the find. What trans is with it? 10 bolt rear-end?
Can we have a little more info on the truck and what your ideas are please?
Old Oct 19, 2009 | 09:20 PM
sierra69's Avatar
stock 4l60-e w/ monster rebuild,until i can afford to buy a 4l80-e. and the stock 10 bolt for now, w/a tru trac & 3:73s. my truck only sees city and highway driving.not much off road,it a 2wheel drive. and im tired of these yuppies w/ there titans and tundras blowing the doors off my american made truck! can i get 400 or 450 hp out of a 6.0l with out stroking it.
Old Oct 19, 2009 | 10:26 PM
L7 Sierra's Avatar
I would try a 6.0 with L-92 heads, 10.5 compresion ratio, and a good cam with roller rockers. If built right they can get at or over 500 crank HP. For about 450 crank HP you could use LS-6 style heads which are a bit cheaper, but the accesories are what cost on this swap.
4l60 with a monter rebuild starts at $2500 plus convertor.
4L80 used with lowish miles is around $800 average plus convertor. Add a good shift kit, and you'll have transmission better then any 4L60.
Most convertors suitable for you idea start at $800.
Other then that you need some deep gears like 3.73's or 4.11's depending on which size motor you go for, and how steep a convertor you decide to get. You could also try 275/60/17's with a 250 treadware which will help traction but also reduce recripricating weight.
Old Oct 20, 2009 | 08:46 PM
sierra69's Avatar
the 6.0l w/ l-92 heads sound better,and the used trans makes it more in my reach. so what cam will match the l-92 heads? then i can match the convertor and gears for the combo.and what intake will work with these heads?
Old Nov 20, 2009 | 08:34 PM
VINCE's Avatar
Shorty Director
I thought the L92's were too much for the 6.0L? How will that do much for low end grunt?
Old Nov 20, 2009 | 08:36 PM
00ChevyScott's Avatar
Wearin' da big hat
The OP mentioned possibly building a 408.
Old Nov 22, 2009 | 11:59 AM
sierra69's Avatar
the cam i want to use is a compcams xer273hr,pt#54-444-11.comp recommends this cam for my 6.0 buld.what do you guys think?
Old Nov 22, 2009 | 12:54 PM
fastnblu's Avatar
Most convertors suitable for you idea start at $800. ...
Accessories are what costs? What do u mean by that?
calsdad
Jun 14, 2023 11:07 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
00loudchevy
Dec 3, 2015 05:54 PM
Wrecker 426
Sep 30, 2015 09:39 PM
Cammed4ever
Sep 30, 2015 03:38 PM
