need help with choosing a cam
Old Jun 29, 2011 | 01:22 PM
tenman33's Avatar
Registered User
thanks everybody for the help im new at this performance trucks site but thanks again
Old Jun 29, 2011 | 01:42 PM
1slowz71's Avatar
A good cam for a 5.3 ecsb I think would be a 245/248. 643/643 on a 108lsa+2 perty good and choppy !
Old Jun 29, 2011 | 01:46 PM
1slowz71's Avatar
^^^ j/k can't go wrong with a quick search and depending on your stall speed. Gear ratio over all weight and intake and exhaust mods , once you have all tha figured out it will be easier to make a wise choice o a cam good luck
Old Jun 29, 2011 | 05:22 PM
4x4shmelty's Avatar
Registered User
Have to do any milling on the heads. Or just take all the stock stuff out and put new in and your good to go. Ya looking for a exhaust and headers on eBay.
Old Jun 29, 2011 | 05:37 PM
1slowz71's Avatar
huh ???????????????
Old Jun 29, 2011 | 05:48 PM
Beau@SDPC's Avatar
Trucks Sponsor
You can mill the heads if you wanna bump compression, but its not necessary. Change springs and you'll be good to go! As far as headers, Pacesetter makes an economical header. Kooks or Dynatech make quality stuff as well if you want to spend some extra coin.
If you're on a budget, the HT1Cam w/ LS6 Springs can be had for under $450. Add a set of Pacesetter LTs Y/Pipe for another $550 and you have yourself a good running truck.
Old Jun 29, 2011 | 08:52 PM
4x4shmelty's Avatar
Registered User
550 for all that sounds good! Off topic. Truck always says low coolant but then I look and it's fine....
Old Jun 29, 2011 | 09:52 PM
budhayes3's Avatar
PT's Slowest Truck
There's a coolant level sensor in the overflow, it may be faulty or sticking, or the wiring/connector to it may be corroded.
Denali08
Aug 9, 2015 04:34 PM
sTNT971
Aug 7, 2015 09:05 AM
steves86ta
Jul 28, 2015 10:21 AM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
