Need DOD swap parts list
Old Nov 25, 2009 | 08:00 PM
lucky77's Avatar
Banned
Originally Posted by Gregory
A super easy way to delete the DoD is electronically through the engine control module. HP Tuner software can do it. If you have an older ECM, then I doubt it would be activated. I mention this as an easy option.
yeah that's the easy way out ,. . but the DOD lifters are still there (which Suc* ) + DOD valley cover which is prob like 15 psi lower oil pressure than NON-DOD ...
Old Nov 25, 2009 | 08:04 PM
lucky77's Avatar
Banned
Originally Posted by DOA
IS anyone running A CAM in a DOD engine? I don't mind deleting the DOD electronically, but Physically is a whole other issue.
What would be the worst thing that could happen if one of those DOD lifters fails? Engine stops running and I need to replace the lifters anyways?
My thought would be if I tear that far into the motor, why don't I replace those heads?
LA
.. the worst it could happen (blown engine)
if a lifter fails- there goes ur cam/pistons . .
i've seen it happen where DOD lifter fail at High lift cam's and damages pistons+cam...
.. why dont you just do it right the 1st time..
ls7 lifter's run $120 + LS2/7 valley cover runs $50.. that's all you need. / and its a safe insurance +you can run high lift cam's + sping it all way 7000RPM w/out any problem's...
Old Nov 25, 2009 | 09:07 PM
DOA's Avatar
DOA
It's not so much the parts that are the problem. Just pulling the heads off might take this to a whole differant level for this guy. I also think that if I was to tear the motor up that much, I might As well put differant heads back on since it will be such a time investment for me.
What would make these DOD lifters fail more likely with the new cam? Lift? Is there anyone running a milder cam with the dod lifters?
If I was to put new heads on my 5.3, what would make sense?
Sorry for high jacking this thread.
LA
Old Nov 25, 2009 | 11:11 PM
Gregory's Avatar
LA
Here ya go:
208/216 .554”/.561” 114LSA +4 camshaft (single bolt)
CompCams pushrods
CompCams 26918 valve springs
Plus, 1 5/8" shorties, and under/over drive pulleys.
Net result: 316rwhp/327rwtq SAE 5.
Tuning added about 15 hp/tq. Only about 10 rwhp/lbtq additional camshaft power under 3500 RPM.
Old Nov 26, 2009 | 12:40 AM
guero68's Avatar
Like lucky77 said all you need are those mian parts I just listed everything..since you are already there like most say... just do it right..and i wanted to give the parts numbs for the extra piece..no new gaskets or bolts will eave you waiting around for a tow truck and then your back to tearing it down
iregret
Jul 27, 2015 10:32 PM
Matt331
Jul 26, 2015 09:40 PM
EscaTruck
Jul 20, 2015 11:42 AM
Aboss
Jul 9, 2015 10:28 AM
Mzay
Jul 6, 2015 11:05 PM
