need a cam for lq4 6 speed.
Old Nov 25, 2006 | 05:03 PM
Default need a cam for lq4 6 speed.
What do you guys recommend,its gonna be a lq4 milled heads .030 .041 gaskets ls6 intake 36lb injectors pacesetter longtubes.6 speed with 4.10s or 4.56s havent decided yet.Anyway its gonna be my daily driver ,25 miles a day and maybe dust some stangs and such on the weekend.Thanks guys BTW. this setup is going in a rcsb nbs truck, sorry bout that guys
Old Nov 25, 2006 | 06:38 PM
Sport Side's Avatar
All of that going into your '69?
Old Nov 25, 2006 | 06:53 PM
dirt track racer 81's Avatar
go with a 230+ duration cam
Old Nov 25, 2006 | 07:36 PM
Nah I'm selling my 2500 and gettin a 2000+ rcsb v6 5 speed The camaro is a ls1 6 speed witha g5x3 love that cam but I think its too much for a daily driver in a truck.Keep it comin guys
Old Nov 25, 2006 | 07:41 PM
Who ground your cam and what kind of numbers did you put down with it?This isnt too personal of a ? is it LOL. I was thinkin maybe a 230/230 with something like .580 lift is this too much?
Old Nov 25, 2006 | 08:38 PM
02sierraz71_5.3's Avatar
need more info on rpm range, are the head ports stock, tuning?
I think the stock ports are efficent enough to do it with higher lift and less duration than 230 for the stock cubes
But just by looking at it if you plan on leaving around 3500 rpms I like cams like
220/226 110/107@ .050 Id be shutting the IV around 36 xer or bigger lobes
valve lift should be in the .600-650 range
a cam like this will pull hp out to around 6400 for the ls6 intake and make huge tq at 3k rpms Id be shooting for a 1.5 60ft in that light car with this cam
do a search for PatG on tech I like his cam designs
Id expect her to pull the tears out of your eyes when she leaves, plus it will have alot of street manners
Old Nov 25, 2006 | 10:18 PM
NO,NO this cam is for my truck not the camaro. Its gonna be 317 heads milled,will have to mail order tune for now to get it on the road then custom tune.
Old Nov 25, 2006 | 10:53 PM
the guy i got it from said its a speedtech f1 cam and it cam doctored at the specs in my sig..on a mustang dyno it did 320 N/A and 451 with a 150 shot..
Old Nov 25, 2006 | 11:14 PM
Id still go along those guidelines just tone it down some tq lower is the key and a cam like the one I specd will make tons of it just drop the dcr for towing and weight purposes something like that on a 112/110 would work well with less lift and xer/xfi type lobes
Old Nov 26, 2006 | 06:43 AM
Grumpy5.3's Avatar
is a cam on a 110 or 108 harder to tune???? just curious
